Thread: LIM Gasket's
Results 1 to 20 of 43
  1. #1 Re: LIM Gasket's
    Brewcity, WI
    Its normal....this is what mine looked like at 123K
    About three rolls of paper towel and 3 cans of cleaner worked.
    Self-denied SMGPFC member #1
    SEARCH works!
  2. #2 Re: LIM Gasket's
    St. Louis
    Totally normal. Just soak up all the oil so you can find the 2 hiddem LIM bolts. Should be one in the back pass. side and one in the front drivers side. People miss those all the time and wonder why a 6 foot pry bar doesn't take the LIM off, lol... BTW, do not use a pry bar
  3. #3 Re: LIM Gasket's
    Brewcity, WI
    Quote Originally Posted by FordMan77 View Post
    I won't lie, I did that... also put the LIM back on without the gaskets....
    SEARCH works!
  4. #4 Re: LIM Gasket's
    St. Louis
    Quote Originally Posted by Pepino View Post
    That's ok. At least you didn't forget to block of the intake runners while the LIM was off and "misplace" a small bolt. You know what that gets you- a motor w/ 5 cylinders
  5. #5 Re: LIM Gasket's
    Nov 2010
    White Lake, MI
    Thanks for the info. Is the oil there because of the bad gasket?
    How well do I need to clean the inside of the plenum? mine is black with a nice layer on it.
    2005 Pontiac Grand Prix, Base, 3800, N/A
  6. #6 Re: LIM Gasket's
    make it shine if you can, brake clean the piss out of it.
  7. #7 Re: LIM Gasket's
    Grand Rapids, MI
    you phail. royally.
  8. #8 Re: LIM Gasket's
    Nov 2010
    White Lake, MI
    bought more brake clean, will the plastic removable piece inside the plenum hold up to the cleaner? or what should i use on it?
    thanks.
  1. Oil Pan Gasket
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 12-31-2011, 07:07 PM
  2. LIM gasket
    By zildjian102 in forum General Tech Discussion
    Last Post: 03-11-2011, 03:45 PM
  3. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  4. L26 Oil Pan gasket?
    By timboku in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2010, 10:53 PM
  5. LIM gasket
    By gtpinsc in forum General Tech Discussion
    Last Post: 10-21-2008, 03:37 AM
