Thread: what Down pipe to get for my N/A 3.8
Results 1 to 20 of 21
  1. #1 what Down pipe to get for my N/A 3.8
    Jersey
    Ok so i now have the wizard intake and SLP GTX exaust. I wanna a new DP that i can bolt on with a high flow cat but i cant figure out which one to get, i was looking around and the Wbodystore has a DP, ZZp has DP's, and 3800performance has DP's as well, any ideas? or are they mostly the same?
  2. #2 Re: what Down pipe to get for my N/A 3.8
    Feb 2008
    For the most, they're the same thing. I mean a downpipe is a downpipe. The differences will be in diameter and craftsmanship. I have a ZZP DP and have no complaints whatsoever, so I would tell you to go with them.
  3. #3 Re: what Down pipe to get for my N/A 3.8
    Jersey
    thanx for the input, that brings me to my next question, if i ordered the ZZP 3" DP Bolt on with cat..do u know if it would still bolt up to my exaust, or would i need a 3" flange on my exaust?
  4. #4 Re: what Down pipe to get for my N/A 3.8
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by 99prixgt View Post
    Um... go have 3" exhaust put on instead? Not really much point to put that downpipe on if it immediately has to go back into tiny pipe.
  5. #5 Re: what Down pipe to get for my N/A 3.8
    Erie, PA
    2.5'' would be best for the N/A unless you have future plans 3'' is a waste, if money is an issue preformance peddler sells a downpipe high-flow cat, etc. for $142. I was going to buy it but its going to be a pain to do by myself
    99 GP GT coupe on Chrome 18's with a K&N air intake
    R.I.P. Firefighter Michael D. Crotty whom anwsered his last alarm on April 8, 2008
  6. #6 Re: what Down pipe to get for my N/A 3.8
    GTX Level Member webracin's Avatar
    Arkansas
    Hogan Performance has good ones as well. Make sure you get a stainless DP so it does not rust out on you in a couple of years. Also not all DPs are the same. Some come with a cheaper flex that will tick on you. If you dont mind the tick, go with the cheaper, but in my opinion its better to spend the 10 or 20 bucks more and go with the interlocking flex.
    All of these are bolt ons.....
    Hogan has Stainless Steel downpipes with high flow cat and interlocking flex for about 220.00.
    The no cat with interlocking flex and stainless is about 180.00
    The cheapest one he has for a N/A is a aluminized 2.5 inch no cat and its 100.00
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  7. #7 Re: what Down pipe to get for my N/A 3.8
    Bastard Reptile's Avatar
    Kansas City, MO
    With the NA car, the 3.0 may be overkill. I know with GTP's people complain about losing the bottom end, which is fine in my book, because you can't use the torque if you just spin.
    You may be ok with the 2.5 downpipe. IMO Hogan makes the best in the biz.
  8. #8 Re: what Down pipe to get for my N/A 3.8
    Barksdale AFB, LA
    I've got a 2.5" ZZP and it fits the bill. Works great as far as I can tell.
    2009 Subaru Impreza WRX STI
  9. #9 Re: what Down pipe to get for my N/A 3.8
    SE Level Member The_Avenger's Avatar
    Ontario, Canada
    Can someone tell me the advantages/disadvantages between bolt on or weld on, I wont be installing the downpipe (dont want to go through all the work involved) and was wondering if I should just get one that can be welded on by the installer to ease any worries of the thing coming loose one day.
    Yes/No?
    2004 Grand Prix GT - 75xxxkm - Inferno Package (no hood), Wizaired CAI, ZZP Strut Tower Brace, 180 T-Stat, Throttle Body Heat Shield, more to come...
  10. #10 Re: what Down pipe to get for my N/A 3.8
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I know, late to the party, but as other people said, unless you're going big with your mods, go for a 2.5" DP. If you want aluminized, you have a lot of choices, but the only stainless 2.5" DP I've seen is ZZP's.
    Avengr, bolt on replaces the entire downpipe, cat, and ubend, so you can just bolt it into the car. Weld on only replaces the downpipe, so you weld it to your stock cat and need to get the ubend removed separately if you want to.
    2001 Buick Regal LS - Almost Stock
  11. #11 Re: what Down pipe to get for my N/A 3.8
    Ontario, Canada
    Ahhh I see thanks for the info, 2.5" bolt on it is then.
  12. #12 Re: what Down pipe to get for my N/A 3.8
    Erie, PA
    Do you know if I would pass emissions tests if I get a high-flow cat
  13. #13 Re: what Down pipe to get for my N/A 3.8
    May 2008
    staten island,NY
    i have a 2.5 catless dp and im supercharged, i used to be N/A
  14. #14 Re: what Down pipe to get for my N/A 3.8
    Ontario, Canada
    Quote Originally Posted by QwikGT View Post
    How hard was the switch over? What was the final cost? I am thinking of the top swap but would rather go turbo if SC is expensive and time consuming.
  15. #15 Re: what Down pipe to get for my N/A 3.8
    TDCRacing
    Guest
    Quote Originally Posted by The_Avenger View Post
    The question is how fast are you wanting to go?
  16. #16 Re: what Down pipe to get for my N/A 3.8
    May 2008
    staten island,NY
    i did my SSM90 kit for $1200 bucks. but i also bought a short stack intercooler kit so subtract $550 from that. i didnt want the turbo because my car worth $5000 is not going to be worth anything after dumping 10 grand for a turbo and trans
  17. #17 Re: what Down pipe to get for my N/A 3.8
    Jersey
    i paid 2,500 for my GP..im planning on a GTP motor swap and built trans, prolly a whipple down the road
  18. #18 Re: what Down pipe to get for my N/A 3.8
    Ontario, Canada
    1k plus some install work eh? Thats alot cheaper then I thought it would be perhaps I should put my money towards that instead of silly little mods.
  1. Drooping tail pipe
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 06-27-2008, 11:12 PM
