Thread: Weird issue/sound
Results 1 to 11 of 11
  1. #1 Weird issue/sound
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    So...I'm running into a very odd issue and i'm at wit's end to figure it out. Only mod to the car is a makeshift intake, plastic autozone tubing with a cone filter attached and a hole drilled for the sensor. Only work that has been done recently is the PCV valve was changed just because I was in Advance and couldn't remember the last time I changed it. We did try a new one just to make sure I hadn't gotten a faulty one.
    The problem : still runs fine, no issues there. BUT it make a very odd semi screeching noise that cannot be isolated to anywhere in the engine bay, also there is the occasional 'chirping' sound.....
    The odd part : The car is running, remove the oil filler cap A) there is a strong suction holding the cap on, B) the odd sound stops, and C) the motor runs much better.
    My father and I checked around thinking it may be a vacuum leak or a vacuum line is plugged causing a vacuum in valve cover, we checked the majority of vacuum lines we could find/check including the brake booster line etc, no problems found.
    Went by Advance Auto and O'reily's nobody had ever heard of an issue like this and was stumped.
    I managed to grab a video, excuse the filthy engine bay and the fact I couldn't find the throttle body cables haha.
    Uploading video, will be posted momentarily....
    Anyone have any ideas?
    edit : oh and it has 116,xxx....just had an oil change (was present before oil change)
  2. #2 Re: Weird issue/sound
    Feb 2009
    Roanoke, VA
  3. #3 Re: Weird issue/sound
    hmmm, i would have to say its the pcv, but you just replaced it twice, did you replace the little orings aswell?
  4. #4 Re: Weird issue/sound
    Feb 2009
    Roanoke, VA
    that was going to be my next question.....what o-rings? I just went out there and checked.... Remove the cap/sensor adapter, one big orange o-ring on the inside of the engine mount side. Ridged orange seal on sensor.....only two rings/seals I see....am I missing one? also if it matters the ribbed orange seal on the sensor is not in the greatest shape....
  5. #5 Re: Weird issue/sound
    Feb 2009
    Roanoke, VA
    I don't have an o-ring like this....
    Google Images can anyone confirm a 2002 GP GT should have that o-ring?
  6. #6 Re: Weird issue/sound
    St. Louis
    Yes, you should have an o-ring on the PCV itself, then the larger one where the MAP housing snaps on top. Does yours have a spring in between the PCV and MAP housing? Think that's supposed to be there too.
    You have a vac leak by not having that lower o-ring on, hence the suction at the oil fill cap and the noise. Its vacuum. The motor will run like crap until you fix that.
  7. #7 Re: Weird issue/sound
    Dec 2008
    chicago
    Had the same problem,went to advance and purchased the pcv kit 2 o rings pcv spring and the top which holds the sensor,installed it now no more noise and it only cost 22.00
  8. #8 Re: Weird issue/sound
    Feb 2009
    Roanoke, VA
    Sorry to revive an old thread, just thought I would add some closure. I was missing the O-Ring on the PCV valve and that caused the issue.
  9. #9 Re: Weird issue/sound
    Only took 2 years to figure that out?
  10. #10 Re: Weird issue/sound
    Feb 2009
    Roanoke, VA
    Quote Originally Posted by slick2500 View Post
    Haha no, I just realized how much I rely on searching to solve my own problems, and I wanted to put an answer in here so if someone else comes looking for a similar problem they'll find an answer and not an open ended thread.
  11. #11 Re: Weird issue/sound
    St. Louis
    Quote Originally Posted by Brammer View Post
    You sir get a star for the day. I wish more people thought to do that. Nothing pisses me off more than coming across a post of a problem I may have, but then the OP never said what the fix was!
  1. Weird sound coming from front end...
    By zql8tr in forum Brakes/Suspension/Chassis
    Last Post: 11-26-2011, 11:19 AM
  2. Weird sound coming from belts
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2010, 10:48 PM
  3. Weird sound on acceleration?
    By CSteen85 in forum General Tech Discussion
    Last Post: 05-01-2010, 10:20 PM
  4. Weird sound, transmission??
    By thelost1123 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-15-2009, 04:23 AM
  5. weird sound when i turn the wheel...
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-29-2008, 01:33 AM
