Thread: What you guys using for an oxygen sensor wrench?
Results 1 to 12 of 12
  1. #1 What you guys using for an oxygen sensor wrench?
    Oct 2013
    Clovis, California USA
    After having that misfire, I know it's just a matter of time before the catalytic converter is toast. I watched a YouTube video on how to do a back pressure test. All you do is remove the upstream oxygen sensor and install a back pressure gauge. You're not suppose to have more than 2 PSI back pressure at any RPM. What's a good oxygen sensor wrench?
  2. #2 Re: What you guys using for an oxygen sensor wrench?
    Crescent wrench or I bought a o2 socket wrench but u can also wrench them from autozone etc
    04 Comp G.
  3. #3 Re: What you guys using for an oxygen sensor wrench?
    Based on most of our sensors being a long body, I picked up the one that is open, the ratchet goes on the side of it.
  4. #4 Re: What you guys using for an oxygen sensor wrench?
    Oct 2013
    Bill, you mean the crowfoot style right? Is there any specific brand or part number you prefer?
  5. #5 Re: What you guys using for an oxygen sensor wrench?
    Florida
    I have the socket that has an offset for the rachet. Works great and fits anywhere an O2 can
  6. #6 Re: What you guys using for an oxygen sensor wrench?
    Omaha, NE
    They're all about the same. I think both mine are "OEM" brand or whatever Autozone carries.
  7. #7 Re: What you guys using for an oxygen sensor wrench?
    why can't you just use a wrench like a normal human being?
  8. #8 Re: What you guys using for an oxygen sensor wrench?
    This is the style I use. I find it much easier than trying to stuff a wrench down behind the motor and not getting decent leverage.
    http://www.harborfreight.com/3-8-eig...nch-97177.html
  9. #9 Re: What you guys using for an oxygen sensor wrench?
    i understand why, i guess i just never had any issues with it and i had it in/out more than a handful of times.
  10. #10 Re: What you guys using for an oxygen sensor wrench?
    I've had a few roll in that required the car running to keep the pipe hot in order to get the damn thing out. It's amazing how much of a fighter they can be at times.
  11. #11 Re: What you guys using for an oxygen sensor wrench?
    SE Level Member jkroll17's Avatar
    Mar 2013
    Eastpointe MI
    There's a nice o2 sensor snap-on wrench I use that's perfect. Its a bent handle and the socket part swivels. If you don't mind spending money that is on something you could use a regular wrench for
    Sent from my RM-860_nam_usa_100 using Tapatalk
    2000 gt coupe I'm on a first name basis with tow truck drivers
    New crate 3800 v6 N/A, Borla exhaust, crappy K&N cold air intake. The rust makes my car lighter and faster.
    >> http://www.grandprixforums.net/showthread.php?t=83513 <<
  12. #12 Re: What you guys using for an oxygen sensor wrench?
    Pennsylvania, USA
    I'd avoid the auto zone crap, mine flexed open way too much and rounded off my downstream of. I got a decent one from NAPA and it has zero flex.
  1. o2 oxygen sensor
    By brian a in forum General Grand Prix Discussion
    Last Post: 09-26-2013, 08:14 PM
  2. oxygen sensor
    By kenjr in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-24-2013, 04:34 AM
  3. Oxygen Sensor
    By mick777wauchope in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2012, 05:50 PM
  4. Oxygen Sensor
    By LowRidinCrew in forum General Tech Discussion
    Last Post: 06-15-2011, 12:55 PM
  5. Oxygen Sensor
    By BwolfGT in forum Off Topic Discussion
    Last Post: 11-21-2009, 05:44 PM
