Thread: 2004 GP 3800 Series III will stall upon starting unless throttle given?
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: 2004 GP 3800 Series III will stall upon starting unless throttle given?
    GT Level Member 04 GTP COMP G's Avatar
    Jul 2008
    Saskatchewan, Canada
    WOW i can't believe how dirty my tb was. Bought some tb cleaner from Canadian tire sprayed her down and what a difference.
    LIVE LIFE FULL THROTTLE!!
  2. #22 Re: 2004 GP 3800 Series III will stall upon starting unless throttle given?
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    I couldn't beleive how dirty mine was either. It seems to run better now and have better throttle response. It still stutters or stumbles a bit when I quickly snap the throttle open though for some reason. It would be nice to get that one solved as well.
  3. #23 Re: 2004 GP 3800 Series III will stall upon starting unless throttle given?
    SE Level Member Randy_W's Avatar
    May 2008
    sALISBURY, md
    Quote Originally Posted by WhiteGT View Post
    Did you use a toothbrush to scrub all around? If not you may still have a hangup, also spray the area around the pivot shaft good as well.
  4. #24 Re: 2004 GP 3800 Series III will stall upon starting unless throttle given?
    May 2008
    Ontario
    Quote Originally Posted by Randy_W View Post
    Yep, I scrubbed it out good with an old toothbrush, looked almost like new in there when I was done. Still, when I snap the throttle quickly it stumbles before it revs up for some reason.
  5. #25 Re: 2004 GP 3800 Series III will stall upon starting unless throttle given?
    SE Level Member prixgt04's Avatar
    Waterbury, CT
    my 04 gt does the same thing. i thought mine was the only one.
  6. #26 Re: 2004 GP 3800 Series III will stall upon starting unless throttle given?
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    I notice a little stutter on my '00 GT if I mash the puddle down. It's like the entire engne cuts off for about a 1/4 second. I figure my tb has to be downright nasty.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  7. #27 Re: 2004 GP 3800 Series III will stall upon starting unless throttle given?
    May 2008
    Ontario
    Quote Originally Posted by Deezul_AwT View Post
    Mine is still doing doing the brief stutter, exactlly as you described even after cleaning the very dirty throttle body. I am wondering if it is a sensor causing the problem. I have scanned the car a few times already but nothing ever shows up.
  8. #28 Re: 2004 GP 3800 Series III will stall upon starting unless throttle given?
    Feb 2008
    Cumming GA
    I'll have to try the same thing in my Impala and listen for it. Might not be able to hear it over the exhaust, though.
  9. #29 Re: 2004 GP 3800 Series III will stall upon starting unless throttle given?
    SE Level Member skubasteve!'s Avatar
    Apr 2008
    Stupid question, but can anyone do a quick 1. 2. 3. writeup for me on how to do this?
    Is it as simple as taking off the airbox, and tubing and the TB is right there then I just scrub her down?
    Any info would be greatly appreciated.
    Steve
    Mine: 2004 Jeep Grand Cherokee Columbia Edition 4.7HO
    Hers: 2004 Pontiac Grand Prix GT-Stock
  10. #30 Re: 2004 GP 3800 Series III will stall upon starting unless throttle given?
    May 2008
    Ontario
    Quote Originally Posted by skubasteve! View Post
    Steve
    Your best bet would be to disconnect everything from the throttlebody and remove it completelly before cleaning it. If you just take off the airbox and tubing, there is a screen over the opening of the throttlebody. If you have some basic knowledge of working on engines you should be able to manage it fairly easily.
  11. #31 Re: 2004 GP 3800 Series III will stall upon starting unless throttle given?
    Barksdale AFB, LA
    The MAF screen for the Series III engines isn't in the throttle body (since the MAF isn't in the throttle body). Taking off the tubing leaves the throttle body wide open.
    2009 Subaru Impreza WRX STI
  12. #32 Re: 2004 GP 3800 Series III will stall upon starting unless throttle given?
    Aug 2008
    Louisville
    got mine cleaned up. WOW what a diff. thx guys!
  13. #33 Re: 2004 GP 3800 Series III will stall upon starting unless throttle given?
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    I just cleaned out my TB this past weekend. God it was basically completely black inside. I can't believe how ditry it was. I used Chemtool B-12 to clean it out. Jesus, I didnt even need a toothbrush to help with the cleaning, the inside of the tb was sparklingafter about 15 total seconds of spraying. I'm going to be using the crap for the rest of my life.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  14. #34 Re: 2004 GP 3800 Series III will stall upon starting unless throttle given?
    Charlotte, NC
    Cleaning the throttle body on my son's 2004 GP GT2 solved his start/stall problem also. Thanks for the help from this forum! Prior to cleaning, using my Autoenginuity ODBII scan tool I could see that the throttle plate was open 7 percent at idle. After cleaning it was at 1 percent. My conclusion is that the plate could not close completely due to the carbon build up. Also, while cleaning, I noticed that with the engine off, that the throttle plate rests at about 15 percent open, apparently with springs or something inside the throttle plate motor (not sure how it's done). If I moved the throttle plate closed with my finger, it would "stick' closed and not return to it's rest postion of about 15 percent. After cleaning, the sticking closed did not happen. I'd guess that during the start process the throttle motor closes the throttle plate and it sticks, inhibiting the throttle motor from opening the throttle plate at the rate needed to get the AFR mixture (i.e. air past throttle plate) correct for startup and idle. Even if my speculation here is wrong, I am sure that cleaning the plate fixed this problem. Thanks for the information on this forum folks!
  15. #35 Re: 2004 GP 3800 Series III will stall upon starting unless throttle given?
    Barksdale AFB, LA
    Quote Originally Posted by 04CompG View Post
    I know what you mean:
    http://img.photobucket.com/albums/v3...2/DSC02405.jpg
    I was able to get it this clean prior to returning it to ZZP for a core (didn't want my core charge to get dinged for being too dirty):
    http://img.photobucket.com/albums/v3...2/DSC02440.jpg
    That was with careful use of carb cleaner. I didn't try too hard since it's just a core, but I felt it could've been better. What Chemtool B-12 did you use? Air Intake Cleaner?
  1. Converter stall?Stock axles?
    By PWNED in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-14-2008, 11:51 AM
  2. 3800 series II Vin 1 - Pulley swaps
    By sledneck907 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2008, 01:08 PM
  3. GP Wants To Stall
    By BADAZGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2008, 07:41 AM
  4. 3800 Series III 1/4 Mile
    By gp04 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2008, 03:40 PM
  5. L32 (2004) 3800 Series III cover
    By mcg_999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 02:59 PM
