Thread: Changed o2 sensor and Still throwing out same codes!?????
Results 1 to 18 of 18
  1. #1 Changed o2 sensor and Still throwing out same codes!?????
    Jul 2011
    Michigan
    I just changed the o2 sensor in the gp. Took it to auto zone and it is still pulling the same codes. The guy asked me when I changed it and I told him about 20 minutes ago and he said it takes 2-3 days for it to register for the codes to go out. Is that true?
  2. #2 Re: Changed o2 sensor and Still throwing out same codes!?????
    London Ont, Canada
    clear the codes, or disconnect battery for like an hr to clear em.. if they come back its no good, if not, problem solved.
  3. #3 Re: Changed o2 sensor and Still throwing out same codes!?????
    did you clear the codes after you changed it?
    damit monk beat me to it
    SMGPFC Member #10
  4. #4 Re: Changed o2 sensor and Still throwing out same codes!?????
    GT Level Member WHT98GTP's Avatar
    Monroeville
    Once u clear the code, if the problem is corrected you should be all set... My girls cobalt had the same problem, changed the sensor twice to make sure, still throwing a code. Pretty sure its in the wiring between the sensor and the pcm... Wiring repairs fail.
    *2002 Buick LeSabre Custom* Bronzemist Metallic * SS Headers *4" FWI*
  5. #5 Re: Changed o2 sensor and Still throwing out same codes!?????
    Jul 2011
    Michigan
    Nope didnt know you could clear the codes? How do I do that?
  6. #6 Re: Changed o2 sensor and Still throwing out same codes!?????
    London Ont, Canada
    Read my post.
  7. #7 Re: Changed o2 sensor and Still throwing out same codes!?????
    Jul 2011
    Michigan
    Sweet Thanks!
  8. #8 Re: Changed o2 sensor and Still throwing out same codes!?????
    Jul 2011
    Michigan
    Have the battery disconnected now I will wait an hour or so.
  9. #9 Re: Changed o2 sensor and Still throwing out same codes!?????
    Omaha, NE
    Autozone should have cleared them after they were read.
  10. #10 Re: Changed o2 sensor and Still throwing out same codes!?????
    there not allowed to do that anymore
    SMGPFC Member #10
  11. #11 Re: Changed o2 sensor and Still throwing out same codes!?????
    London Ont, Canada
    good stuff!
  12. #12 Re: Changed o2 sensor and Still throwing out same codes!?????
    London Ont, Canada
    yeah but ive heard you guys say Autozone are a bunch of idiots sometimes
  13. #13 Re: Changed o2 sensor and Still throwing out same codes!?????
    Jul 2011
    Michigan
    Alright connected the battery took it to auto zone and I did ask if they could clear the codes and he told me they are not allowed to do that but he could tell me how to do it but I have to press the button. Either way doesnt matter because he plugged it in and there were NO codes!!! Thanks for your help again guys!
  14. #14 Re: Changed o2 sensor and Still throwing out same codes!?????
    well no codes yet, the car has to go though a drive cycle to check everything before itll throw a code, or as it see's a problem then it will throw one
    SMGPFC Member #10
  15. #15 Re: Changed o2 sensor and Still throwing out same codes!?????
    London Ont, Canada
    yeah i say drive it for a few days, then take it in, see if it has anything goin on.
  16. #16 Re: Changed o2 sensor and Still throwing out same codes!?????
    Jul 2011
    Michigan
    alright sounds good!
  17. #17 Re: Changed o2 sensor and Still throwing out same codes!?????
    This feels like a dick move.
    What where the codes? Because swapping an O2 only fixes an O2 heat/inactivity code.
  18. #18 Re: Changed o2 sensor and Still throwing out same codes!?????
    Jul 2011
    Michigan
    p0137
    p0138
    p0140
  1. 98 gtp Odd stalling, changed crank sensor
    By BoostedGrandPrix in forum General Tech Discussion
    Last Post: 08-20-2011, 08:50 PM
  2. Throwing all my GTP parts into the trash
    By BobC in forum 1991-1994 5 speed Manual (GETRAG 284,282)
    Last Post: 08-13-2011, 06:42 AM
  3. Throwing codes
    By batman1988 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2011, 03:37 PM
  4. throwing a code ive never seen before, helppp!!
    By kirkkarem1212 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2010, 08:06 PM
