Thread: Where is Crankshaft Position Sensor Located on 04 grandprix gt
Results 1 to 6 of 6
  1. #1 Where is Crankshaft Position Sensor Located on 04 grandprix gt
    SE Level Member mikev14's Avatar
    Jul 2011
    Texas
    Im trying to find the location of a Crankshaft position sensor on my grand prix gt 04 cause my engine has been turning off whille running for about 15-20mins and then it will turn on after 10-15 of cool time and already checked the gas pump and coils and there fine so this is my last option to trying to fix the problem
    please help
    detail and/or pics will be of great help
  2. #2 Re: Where is Crankshaft Position Sensor Located on 04 grandprix gt
  3. #3 Re: Where is Crankshaft Position Sensor Located on 04 grandprix gt
    Jul 2011
    Texas
    Thanks, ill try putting it first thing tomorrow
  4. #4 Re: Where is Crankshaft Position Sensor Located on 04 grandprix gt
    Crank sensor
    It's location on the motor
    In front of it is the plastic shield
    And balancer (M6-1.00 - ~75mm bolts)
  5. #5 Re: Where is Crankshaft Position Sensor Located on 04 grandprix gt
    SE Level Member fakir's Avatar
    Mar 2012
    Edinburg, TX
    does that mean taking off the belt in order to get to the sensor, I have the same problem.
    It's not on the bottom of the car right? It's on the side close to the water pump, right?
  6. #6 Re: Where is Crankshaft Position Sensor Located on 04 grandprix gt
    St. Louis
    Yes, you have to remove the belt, the splash sheild in the pass. wheelwell, the harmonic balancer from the crankshaft, then the plastic cover for the CKPS. You need a puller w/ the correct size bolts to remove the balancer correctly. Search for it here, I know it's been posted recently.
  1. Crankshaft Position Sensor Replacement [*]
    By SyntheticShield in forum How To Write-Ups/Tech Tips
    Last Post: 11-23-2014, 12:54 AM
  2. Does anybody know where the IAC sensor or TB screen is located??
    By nickdemio in forum General Tech Discussion
    Last Post: 03-27-2011, 04:10 PM
  3. Replaced Crankshaft position sensor, now won't start
    By 03grandprix in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-05-2010, 09:22 AM
  4. bad crankshaft position sensor?
    By ChdMcD in forum General Tech Discussion
    Last Post: 08-13-2010, 01:06 PM
  5. Trouble History With Crankshaft Position Sensor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 12-23-2008, 09:43 PM
