Thread: High idle glowing hot manifolds weak power
Results 1 to 7 of 7
  1. #1 High idle glowing hot manifolds weak power
    Jul 2011
    Springfield mo
    I have 2002 grand prix GT 3.8 replaced the LIM and UIM gaskets and everything went fine a couple days later I took it on a long trip. On the way back it started losing power it would rev up really high but not go anywhere kind of like how people describe they have a clogged cat, and then it started idling really high like 2500 rpm.
    I rented a code reader from autozone it came up bad iac tps and maf. I replaced the iac and tested the other 2.
    I drilled a 1/2 inch whole before the cat so I don't think that's the problem
    I noticed my exhaust manifolds are glowing hot so I must be running lean. I checked for vacuum leaks by spraying starter fluid around areas that could potentially be leaking
    I didn't replace the o-rings on the injectors. If one is leaking could it cause this?
  2. #2 Re: High idle glowing hot manifolds weak power
    Out West
    wow. glowing hot
  3. #3 Re: High idle glowing hot manifolds weak power
    Jul 2011
    Springfield mo
    Haha yeah it's kinda wicked. Other people have had it though I searched
  4. #4 Re: High idle glowing hot manifolds weak power
    clogged cat?
    Without a wideband you can't tell if you're running lean.
    If the upper injector o rings were leaking you'd have fuel spraying all over the place.
    if the lowers are leaking you'd have a vacuum leak.
    which normally shows up as a bank 1 running lean. which suggests vacuum leak.
  5. #5 Re: High idle glowing hot manifolds weak power
    GTX Level Member bandits grand prix's Avatar
    Jul 2010
    connecticut
    take a pic of the glowing hotness lol
  6. #6 Re: High idle glowing hot manifolds weak power
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    clogged cat?
    X2!!
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  7. #7 Re: High idle glowing hot manifolds weak power
    Clogged cat...or your timing is way off...only really the 2 ways your manifold will be glowing red hot.
  1. glowing red exhasust manifolds!!!!!
    By jj7ski in forum General Tech Discussion
    Last Post: 12-12-2010, 10:51 PM
  2. glowing red exhaust manifolds
    By GTP Ryan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-30-2010, 07:40 PM
  3. 4.0 Ford Explorer Weak Idle
    By SlowNA06 in forum Off Topic Discussion
    Last Post: 10-13-2010, 02:04 PM
  4. Glowing manifolds, what could be the cause?
    By Blue Rebel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-04-2010, 12:29 PM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
