Thread: Brainstorming: Crazy Talk?
Results 1 to 18 of 18
  1. #1 Re: Brainstorming: Crazy Talk?
    GT Level Member Wrongwayislost77's Avatar
    Arvada, Colorado
    We both have fairly heavy feet and as such, we are looking to avoid turbo for just the reason stated. More power. The temptation will always be there to turn up the boost, and without a viable transmission chain solution, I can't see it as a better option than the top swap for simple reliability and longevity. And the '67 is the toy anyway, these don't need to be rockets. I'm just spit-balling anyway, as mine is getting a mild setup soon and his is only getting a refresh this year.
    A triangulated 4-link for the Camaro is the first priority.
    Sig2
    30%, 5000k's, GMPP/Addco Sways, BMR Braces/Arms, FE3 Struts, WBS Springs, 12" w/ SS Lines & F-Bodies. Wiz, HVTB, HV3, CPlog, Shift Kit, ZZP 1.0, Alt/Volt Boost, Etc.
  2. #2 Re: Brainstorming: Crazy Talk?
    Even so I'd rather learn how to control my foot rather than put a big dent in my wallet.
    Their should be a transmission option available by the new year Id hope. Their are talks on here in the transmission section as well as on CGP about ZZP comming up with something that isnt a GMR 1" chain and their are others working on a solution too like using extend transfer case chains as long as it has a 3/8s pitch for the gears.
    Not to mention if your going to do a top swap you need to add all the belt system too.
  1. Thats right Talk
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 04-09-2011, 02:04 AM
  2. Don't Talk Sh!T
    By KawaFord in forum Off Topic Discussion
    Last Post: 11-26-2010, 11:41 AM
  3. let's talk about timing
    By Poil336 in forum General Tech Discussion
    Last Post: 05-13-2010, 12:37 AM
  4. Talk about a bad day
    By Deimos in forum Off Topic Discussion
    Last Post: 02-04-2010, 09:32 AM
  5. Wow, can we talk her into buying a GTP
    By 03GPScottyd in forum Off Topic Discussion
    Last Post: 11-08-2008, 10:14 AM
