Thread: wrapping headers
Results 1 to 20 of 21
  1. #1 wrapping headers
    GT Level Member GOINDEF's Avatar
    Holly, MI
    I was just curious what headers can be wrapped for our cars and what cant be?
    i have the SD headers and noticed some member pictures with their SD headers wrapped.
    I know the gains of wrapping them, but is it going to hurt them if i wrap the SD headers?
  2. #2 Re: wrapping headers
    Wrapping stainless...meh
    Leave it alone.
  3. #3 Re: wrapping headers
    Holly, MI
    sounds good enough to me, thanks
  4. #4 Re: wrapping headers
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    My buddy has SDs and ran them 1/2 summer, then had them wrapped and sed he noticed a reduction in under hood temps!
  5. #5 Re: wrapping headers
    Holly, MI
    see thats the reason i thought about wrapping them, is cause it would help get the engine bay a little cooler
  6. #6 Re: wrapping headers
    Pennsylvania
    Under-hood temps are great to know... if your car doesn't move.
  7. #7 Re: wrapping headers
    just build a heat shield, and put it between the the cross-over and the thottle body..and take the weather-striping off of the cowl, i removed mine and the engine bay temp dropped like 5-10 degrees
    SMGPFC Member #10
  8. #8 Re: wrapping headers
    SWPA
    Header wrap is a bad idea. Exhaust wrap causes cracked exhaust.
  9. #9 Re: wrapping headers
    Pennsylvania
    You ever notice how tapping a boiling kettle won't burn your finger?
  10. #10 Re: wrapping headers
    Quote Originally Posted by SlowNA06 View Post
    no i havent but i bet this is going to end up being something about how the thottle doesnt trasnfur the heat to the inside of it..or something like that...am i close?
    SMGPFC Member #10
  11. #11 Re: wrapping headers
    Seriously...if you think wrapping the crossover or making a heat shield is going to help underhood temps...I lulz at you.
    The 3800 is a hot running platform...embrace the hotness, and love it.
  12. #12 Re: wrapping headers
    Florida
    just build heat extractors! i guess there is a reason why the Veyron uses 1/3 of its 1000 hp to cool itself! every fluid it has has its own or multiple coolers!
  13. #13 Re: wrapping headers
    Quote Originally Posted by Z34Phoenix View Post
    Yeah, this isn't a 1000HP, million dollar car.
    Just live with it.
  14. #14 Re: wrapping headers
    HUDSON
    Ceramic coating is better. I have it on another vehical and it dramaticly cuts the radiant heat to nearby objects. I had header wrap on a vehical a long time ago and
    it was nasty stuff, made me itch, and stank every time I got into the car.
  15. #15 Re: wrapping headers
    I have 2000* Armor Coating done on my Pacesetter's when I bought them.
    Silver speaks teh truth...it is legitness.
  16. #16 Re: wrapping headers
    Motor generates 987 HP in mechanical power.
    987 HP in heat.
    987 HP in sound.
    Hoooooooooooorrrrrrraaaaaaaaaaaaayyyyy physics.
  17. #17 Re: wrapping headers
    New Jersey
    987 HP in heat.
    987 HP in sound.
    Yea,
    I thought car engines were only something like 20% efficient. So if your producing 987HP you are producing a lot more than 987HP worth of heat.
  18. #18 Re: wrapping headers
    I was under the impression it was around one third.
    987 hp = 736 kW = 2 511 232 BTU/h
    Home furnace might be 100 000 BTU.
    HOORAY!
  19. #19 Re: wrapping headers
    Minnesota
    IMO header wrap is pointless. I don't think you are going to pick up any cooler air just because the headers are wrapped. I will make a bet with anyone to take an engine bay temp of their wrapped header car and compare it to a non wrapped car after driving for 1 hour. I will bet you that there will be little to no difference.
  20. #20 Re: wrapping headers
    only reason to wrap headers is if your running some excessive boost on a turbo because itll burn coatings right off when they burn red hot or if you'd like to wrap them instead of coating them.
    however, like previously said, they will rust from the inside out if not properly wrapped.
  1. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
  2. Wrapping the crossover?
    By the1euge in forum General Tech Discussion
    Last Post: 04-20-2008, 07:04 PM
