Thread: K&N or Weapon X?
Results 1 to 14 of 14
  1. #1 K&N or Weapon X?
    SE Level Member ZachBW55's Avatar
    Ramsey MN
    Hi I was wondering if it was worth putting a cold air intake on my 2000 Grand Prix GT. If so what brand would be better K&N or Weapon X?
    Thanks for looking
  2. #2 Re: K&N or Weapon X?
    Charles City, IA
    Neither make your own with a good dry flow filter
    SMGPFC Two Nipple General
  3. #3 Re: K&N or Weapon X?
    Ramsey MN
    how do I do that? and how does that work with the MAS?
  4. #4 Re: K&N or Weapon X?
    Florida
    just do a search for FWI or fender well intake. you can get filters at autozone and advance auto. for cheep. even the SC guys have no probs with restriction with these filters. if you want the bragging rights to say you spend 250-300 on an intake go ahead but you can build one for under $75 or less!
  5. #5 Re: K&N or Weapon X?
    Ramsey MN
    ok that sounds much better :P thanks for the help!
  6. #6 Re: K&N or Weapon X?
    Ramsey MN
    would just a straight cone filter with the sensor be good or do I want to build the full arm with the heat shield?
  7. #7 Re: K&N or Weapon X?
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    stay away from K&N
  8. #8 Re: K&N or Weapon X?
    Ramsey MN
    I was just at auto zone and I think I may as well go with the $115 Weapon R short ram intake. but why stay away from K&N? I had is in my Grand Cherokee and loved it
  9. #9 Re: K&N or Weapon X?
    Apr 2009
    Too much dirt is allowed to pass through them.
  10. #10 Re: K&N or Weapon X?
    i spent 15 bucks on parts a 20 on a filter, and i have an external maf, couldnt be happier
    SMGPFC Member #10
  11. #11 Re: K&N or Weapon X?
    May 2008
    Winnipeg, MB
    make a heat shield for it, could use a plastic garbage pale cut to fit and lined with heat reflecting duct work insulation found at Home Depot
    2007 Pontiac Grand Prix
  12. #12 Re: K&N or Weapon X?
    Ramsey MN
    Ok I will look a little harder. and see what I can find at napa or somewhere else
  13. #13 Re: K&N or Weapon X?
    Click the link in my signature boss.
  14. #14 Re: K&N or Weapon X?
    Ramsey MN
    Thanks that helped
  1. Weapon R intake 3.1L review
    By Sesleeper in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-27-2010, 10:51 AM
