Thread: Stater issue or transmission?
Results 1 to 3 of 3
  1. #1 Stater issue or transmission?
    SE Level Member miker4792's Avatar
    May 2011
    Oconto Falls
    My starter had a flat spot recently so i replaced it with a brand new starter and it worked great for a week. Today i go to start my car and bam, same thing happened when i discovered the flat spot. i noticed a bolt on starter was a little lose so i tightened it and knocked it into neutrul and it started with no problem. it still is starting great now. any ideas on whats the problem? its a 2000 grand prix se
  2. #2 Re: Stater issue or transmission?
    maybe loose wire somewhere?
  3. #3 Re: Stater issue or transmission?
    When you say flat spot, what do you mean?
    Do you mean the starter spins up w/o catching the flywheel?
    Do you mean that loose bolt let the starter hang down and maybe twist or something odd?
    I'd tighten the bolts like a man, then see if the problem ever comes back.
  1. issue with transmission downshifting
    By 91gpse in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 04-22-2011, 02:06 AM
  2. Transmission issue??
    By xsvtank in forum General Tech Discussion
    Last Post: 11-11-2010, 09:29 PM
  3. 1998 GP GT Transmission Issue
    By Kentus in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-19-2010, 09:46 PM
  4. Possible transmission issue
    By Kurt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-18-2009, 02:02 PM
  5. New transmission not working correct - possible PCM issue?
    By knightmastery in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-31-2008, 05:13 AM
