Thread: Aluminum Framed Gaskets Sealing Problem?
Results 1 to 5 of 5
  1. #1 Aluminum Framed Gaskets Sealing Problem?
    Jun 2011
    illinois
    I am replacing my lower intake gaskets with the aluminum ones and I was wondering if I will have problems with them sealing to the intake manifold. The manifold has some pitting (see pictures below). Comments, suggestions.
    Thanks in advance.
    Right Side
    Left Side
    Big Right Side
    Big Left Side
  2. #2 Re: Aluminum Framed Gaskets Sealing Problem?
    Machining it won't be cheap. (I was quoted $150)
    New manifold might be similar in cost though.
  3. #3 Re: Aluminum Framed Gaskets Sealing Problem?
    SE Level Member Dragon1972's Avatar
    Spray the cleaned surface with some Permatex Copper spray and it will fill in the pits, then install as usual.
    Master Certified Automobile Technician
    1997 GP GT-SC
  4. #4 Re: Aluminum Framed Gaskets Sealing Problem?
    I have seen this many times. It shouldn't be an issue at all. As a seasoned installer, I'd put the new gaskets in and wouldn't use any RTV on the LIM itself (only in the corners where it should be).
    I've seen many worse and they have no problems with a new gasket. Hope that helps.
  5. #5 Re: Aluminum Framed Gaskets Sealing Problem?
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    I wouldn't worry about it, mine were similar and I didn't use anything
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  1. SD Rear header sealing problem...
    By 02grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2011, 02:15 AM
  2. Corner Sealing
    By J_Man55 in forum Visual/Body Modifications
    Last Post: 06-22-2008, 11:04 PM
