Thread: how safe is top swap
Results 1 to 11 of 11
  1. #1 how safe is top swap
    SE Level Member SDgrandprixGT's Avatar
    Apr 2011
    Watertown, SD
    i want to drive my 98 gt for around 6 years as a daily driver. so i was wondering if it would be safe to top swap (without it breaking something every time i turn around)
  2. #2 Re: how safe is top swap
    you can pull it off pretty easily, but if youre like me your car will be down once a month for something stupid.
  3. #3 Re: how safe is top swap
    Apr 2011
    Watertown, SD
    is the m90 kit basically the same thing
  4. #4 Re: how safe is top swap
    Troy OH
    ssm90 kit uses the stock heads, so if you're not mechanically inclined or don't have time or what not, you just replace the intake manifold and fuel rails IIRC, and a few other little things and run it off one belt. you'll need a tune from zzp, and a lot of guys say they have trouble running a stock 3.8" pulley without headers due to higher compression. if you top swap, you have to switch the L36 heads for L67 ones
  5. #5 Re: how safe is top swap
    Ocala, FL
    I debated doing it when I owned my GT. I was actually planning to, until I found a GTP I liked, and bought that instead of top swapping the gt.
  6. #6 Re: how safe is top swap
    GT Level Member zipper's Avatar
    Dec 2008
    Shelby, MI
    It's very safe. A member on clubgp named dbtk had a top swapped GT that made 385ish whp without nitrous (something like 445whp w/nitrous) and the engine didn't blow up until 264k miles. If you go the SSM90 way, be prepared to spend at least $1600 on the kit and start with their 4.2" pulley.
    NA dyno: 222whp
    Novi 1000 dyno: 348whp
    Novi 2000 dyno: 372whp Best 1/4 mile: 13.2634@105.12mph
  7. #7 Re: how safe is top swap
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    That SSM90 kit would be tits if you could run a Gen V and not have to buy $400 fuel rails.
    As long as you have good supporting mods and a safe tune (no KR) you should be fine. Then enjoy having 5% more power than a GTP with better gearing.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  8. #8 Re: how safe is top swap
    or invest in a snail and go even faster.
  9. #9 Re: how safe is top swap
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Mines been SSm90'ed for 5 years with not one issue. Other then the STOCK gt trans is just now slipping.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  10. #10 Re: how safe is top swap
    Apr 2011
    Watertown, SD
    what supporting mods
  11. #11 Re: how safe is top swap
    Hagerstown,Md
    Quote Originally Posted by SDgrandprixGT View Post
    When I first got the ssm90 I ran a 4.0 pulley with a plog and 3 inch downpipe. Ran that set up down to a 3.8 pulley for a year. Then got headers and went to a 3.6 and 3.5 pulley. Im now on a 3.25 pulley . below is how the car sits now
    http://www.grandprixforums.net/green...-gt-42587.html
  1. safe??
    By wlmrt6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2010, 01:58 AM
  2. Will this be safe?
    By Silver GTP in forum General Tech Discussion
    Last Post: 06-08-2010, 01:07 PM
  3. Is this safe?
    By Amb4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2010, 09:48 PM
  4. Safe to run 3.2?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 09-25-2009, 11:20 AM
  5. This looks like fun & safe
    Last Post: 06-29-2008, 09:13 PM
