Thread: Service ABS, traction control, variable steering
Results 1 to 15 of 15
  1. #1 Re: Service ABS, traction control, variable steering
    SE Level Member Lionel's Avatar
    Moncton N.B.
    The power steering still works but its much stiffer, (its better then when the car is off but its noticeably harder than before the warning came.)
    My traction control and abs no longer work either.
    My PS fluid looks fine.
  2. #2 Re: Service ABS, traction control, variable steering
    GT Level Member Tea Time's Avatar
    New Brunswick
    its a a long shot but, ur not missing a serpentine belt r u?
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  3. #3 Re: Service ABS, traction control, variable steering
    Moncton N.B.
    No, my belt is fine, My brakes work, just not the abs. and my power steering works, just not as much as it did, its stiffer.
    Once I replace the hub assembly, I'll repost with an update.
  1. Comments Wanted - 05 Comp G Service Stability/Service Traction
    By JD05CompGTP in forum General Tech Discussion
    Last Post: 03-13-2012, 08:21 PM
  2. service power steering abs system traction control warning
    By ltr450tremor in forum General Tech Discussion
    Last Post: 05-06-2011, 10:14 PM
  3. Reduced Engine Power/Service Traction Control
    By SteveNMe in forum General Tech Discussion
    Last Post: 08-07-2010, 10:36 AM
  4. 04 GTP Service ABS/ TRaction control
    By busagtp in forum General Tech Discussion
    Last Post: 09-07-2009, 12:03 PM
