Thread: Service ABS, traction control, variable steering
Results 1 to 15 of 15
  1. #1 Re: Service ABS, traction control, variable steering
    SE Level Member Lionel's Avatar
    Moncton N.B.
    Also, I know my driver's side wheel bearing is bad, not sure if that has anything to do with it.
    but why would that disable my steering?
  2. #2 Re: Service ABS, traction control, variable steering
    GT Level Member Tea Time's Avatar
    New Brunswick
    the sensor on ur bearing is prolly bad therefore throwing the codes for trac n abs....have u checked ur power steering fluid lately?...is there a whine when u turn the wheel?
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  3. #3 Re: Service ABS, traction control, variable steering
    Moncton N.B.
    I'll check the PS levels and no there was no noise when i cut the wheels.
    If it is the sensor is that something you buy? or does it come with the hub assembly? I need to replace the bearings anyway.
    Also this problem started after driving on a very bumpy road if that helps.
    Just noticed you are a fellow New Brunswicker! I'm sure you know exactly what i mean by very bumpy roads lol
  4. #4 Re: Service ABS, traction control, variable steering
    New Brunswick
    yep...the fact it started on a bumpy road helps...the sensor is built into the new hub assembly(bearing) that u get...
    The steering has me confused tho....does it feel like theres no assistance from the power steering?
    and the roads suck here...
    '97 GTP - Project
  5. #5 Re: Service ABS, traction control, variable steering
    Moncton N.B.
    The power steering still works but its much stiffer, (its better then when the car is off but its noticeably harder than before the warning came.)
    My traction control and abs no longer work either.
    My PS fluid looks fine.
  6. #6 Re: Service ABS, traction control, variable steering
    New Brunswick
    its a a long shot but, ur not missing a serpentine belt r u?
    '97 GTP - Project
  7. #7 Re: Service ABS, traction control, variable steering
    Moncton N.B.
    No, my belt is fine, My brakes work, just not the abs. and my power steering works, just not as much as it did, its stiffer.
    Once I replace the hub assembly, I'll repost with an update.
  1. Comments Wanted - 05 Comp G Service Stability/Service Traction
    By JD05CompGTP in forum General Tech Discussion
    Last Post: 03-13-2012, 08:21 PM
  2. service power steering abs system traction control warning
    By ltr450tremor in forum General Tech Discussion
    Last Post: 05-06-2011, 10:14 PM
  3. Reduced Engine Power/Service Traction Control
    By SteveNMe in forum General Tech Discussion
    Last Post: 08-07-2010, 10:36 AM
  4. 04 GTP Service ABS/ TRaction control
    By busagtp in forum General Tech Discussion
    Last Post: 09-07-2009, 12:03 PM
