Thread: Three codes.. what do you think?
Results 1 to 12 of 12
  1. #1 Three codes.. what do you think?
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    p0327 knock sensor 1 circuit low input, p0322 knock sensor 2 circuit low input, p0336 Crankshaft Position Sensor A circuit range performance... I'm guessing I need to replace the cps, what do you think?
  2. #2 Re: Three codes.. what do you think?
    Not so sure about that chief. I'd go to Gearchatter.com and look up those three codes. Bet there's an intersection in one of the diagnostic aid sections for them and it'll tell you about a ground or bad power from the pcm etc.
    You got something going on...but I doubt it's just one sensor.
  3. #3 Re: Three codes.. what do you think?
    Medford, NY
    well I can rule out PCM because I have two and it happens with both. The codes do not always come up, but the problem is there because while driving it will randomly jerk/hesitate then the tac will drop to 0 and trac light comes on, it will run fine thereafter.
    All I could find from that website is if codes p0327 and p0332 inspect for poor connections at the KS harness jumper. I'm going to double check for bad connections right now.
    hopefully someone has had a similar problem that could help me.
  4. #4 Re: Three codes.. what do you think?
    With the hiccup...go to the crank sensor. You convinced me right there.
  5. #5 Re: Three codes.. what do you think?
    Medford, NY
    okay cool because I couldn't find any bad connections lol i'm not really looking forward to replacing the sensor but hopefully i'll get a chance to this weekend. I'll obviously update this thread after I have replaced the sensor.
    of course right now two of the codes went away (the knock sensor codes) and it's running fine lol the problem will return though i'm sure, it's come and gone for a while now.
  6. #6 Re: Three codes.. what do you think?
    Medford, NY
    replaced the crankshaft sensor.. so far so good.
  7. #7 Re: Three codes.. what do you think?
    The hiccup behavior is too common to the crank sensor to not shotgun one on.
  8. #8 Re: Three codes.. what do you think?
    Medford, NY
    just want to update and finalize this thread, it was the crankshaft position sensor. it's fixed. hopefully this helps some people out.
  9. #9 Re: Three codes.. what do you think?
    Glad to hear you got it fixed...CPS is a fun one.
  10. #10 Re: Three codes.. what do you think?
    Medford, NY
    lol definitely some fun, thanks.
  11. #11 Re: Three codes.. what do you think?
    I can't even milk a CKPS to a full beer. It's so easy. Probably helps that everything needed is in reach eh?
  12. #12 Re: Three codes.. what do you think?
    Medford, NY
    yes, and you should drink faster lol
  1. Codes
    By 04PrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2011, 07:02 AM
  2. My car is FU**** WTF? 48 Codes
    By Toofastgs in forum General Tech Discussion
    Last Post: 12-24-2009, 10:57 AM
  3. Codes for A/C
    By ASTROALCHER in forum Introductions/Noob Questions
    Last Post: 09-08-2009, 12:49 PM
  4. 3 codes, what could it be?
    By spidamanSS in forum General Tech Discussion
    Last Post: 08-19-2008, 02:24 AM
  5. I got some codes
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2008, 07:41 AM
