Thread: Water pump leak, or not?
Results 1 to 20 of 22
  1. #1 Re: Water pump leak, or not?
    id check it while its hot, and hopefully leaking, so you don't fix what ain't broken if ya know what i mean.
    inspection mirrors work nice.
    the rear one goes into the manifold and the alt bracket
  2. #2 Re: Water pump leak, or not?
    Bellevue, Neb. Close to Omaha
    I noticed the heater hoses appear to run out of the alternator bracket. Am I on the right track surmising that coolant runs through the alternator bracket enroute to the heater hoses?
    Is this the reason for those elbows, to route coolant from the intake manifold through the bracket to the heater hoses?
  3. #3 Re: Water pump leak, or not?
    GM got creative that day.
    Typical leaks
    Upper coolant elbow. Oddly enough..you never/rarely see a lower coolant elbow leak
    Water pump weep hole. It won't necessarily drench any pullies.
    O rings where the heater hoses attach to the alternator bracket.
    I think if you did a visual/feel w/o the car running in those areas, you'll find that leak right away.
  4. #4 Re: Water pump leak, or not?
    Wow Bill I guess that is creative of GM to do something like that. Very bizarre. I looked at the heater hoses that run out of the bracket towards to heater core and it was dry. So I will need to remove the alternator to access this other elbow?
    I noticed what I assume is the lower elbow in clear view on the passenger side forward edge of the intake manifold and it seemed to be ok.
    I plan on cleaning the engine bay some and checking for the leak tomorrow morning. Are these elbows press-fitted?
  5. #5 Re: Water pump leak, or not?
    No, they are simply slip fit..but they don't leak...somehow.
    If the top one isn't leaking..then reach up under the water pump pulley and feel for wetness. It's really not bad to find a leak on these cars. If it's not that...maybe a freeze plug?
  1. Massive water leak
    By hahaha38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2010, 07:19 PM
  2. '04 GP GTP Water Leak (Different)
    By Jadentsu in forum General Tech Discussion
    Last Post: 06-23-2010, 12:22 AM
  3. Water Leak......need help....THX
    By jas98gtp in forum 04+ Specifics
    Last Post: 05-16-2010, 11:04 AM
  4. water pump housing leak??
    By 16MustangVet in forum General Tech Discussion
    Last Post: 02-08-2010, 12:06 PM
  5. trunk water leak
    By abweiss in forum General Tech Discussion
    Last Post: 11-25-2009, 08:28 AM
