Thread: oil level low
Results 1 to 13 of 13
  1. #1 Re: oil level low
    GT Level Member johnnyj773's Avatar
    May 2008
    Chicago(southside)
    Thats what I was thinking. You'd have to lose over half your oil for it to trigger the sensor and I dont see that happening without some sign or symptoms of trouble. The bad side of it is that you have to drain the oil out to change it, or at least get it below the level of the sensor hole in the pan. If you end up replacing it, be sure to use some thread sealant.
    thats what might end up happenin.this might sound dumb but i need to know;whats thread sealant?where can i find it?and what exactly am i sealing?and thanx everybody for your input,good lookin out.
    Wizaired cai,taylor 8mm wires,ngk tr55 plugs, msd coils.slp power flo exhaust w/gtx tips. future mods:zzp 1.0 pcm,slp headers, zzp hv3 uim runners ,zzp hv tb,gmpp sway bars,kyb agx struts,18"A.R.M:Rogues wrapped in firestone firehawk gt's.that's all performance wise.
  2. #2 Re: oil level low
    West Central Ohio
    Thread sealant is a thick substance that usually comes in a can. You can get it at the auto parts store. It usually has a threaded cap with a brush attached to it, just paint some on the threads before you screw them in. You don't need a massive amount on there, just enough to fill the threads.
    I have a similar problem. I have 3500 miles on my car since I bought it, 23k total. It's a 2005. The low oil level warning came on the other day. I checked the dipstick and in fact it was low. Put a quart in and the level was good. I am not real happy this thing burns oil with 23k miles on it. I had a 1994 GP and it became a fill the oil and check the gas routine. A quart every 500. Any ideas on this one fellas? It's definitely not leaking it onto my garage floor.
    I'm guessing GM will say that a quart every 3k is within spec. Then they'll remind me I'm out of warranty.
  3. #3 Re: oil level low
    Barksdale AFB, LA
    Mine was leaking it internally onto the LIM, as you can see here:
    http://img.photobucket.com/albums/v3...f/DSC03335.jpg
    It was probably also being burned. I also burned a little oil when I used a PCV valve of a brand other than AC Delco. The AC Delco was cheaper than the Auto Zone brand anyway... Just some suggestions.
    2009 Subaru Impreza WRX STI
  1. Finally no longer SE Level!!
    By GeddyLee in forum Off Topic Discussion
    Last Post: 04-30-2010, 09:47 AM
  2. trans fluid level
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-13-2008, 02:45 PM
  3. GTP Level member
    By IndeedSS in forum Off Topic Discussion
    Last Post: 03-10-2008, 10:16 PM
  4. What Entry Level Struts?
    By RNUOVR in forum Brakes/Suspension/Chassis
    Last Post: 01-15-2008, 09:07 AM
  5. Oil Level Sender Thread
    By Speeder in forum Turbo
    Last Post: 01-08-2008, 09:25 PM
