Thread: Collapsed lifter (Maybe)
Results 1 to 9 of 9
  1. #1 Re: Collapsed lifter (Maybe)
    St. Louis
    ^^I use egg cartons...they work great and the rocker sits right in place as well.
    That's a good idea. Never thought of that! Of course if I quit breaking things that require the pushrods to be removed then that would be better, lol...
    OP- You say you looked at your dog bone and the motor mount is busted? Well, which one is broken, the dogbone (the 2 mounts up front that bolt to the radiator core support) or the ACTUAL motor mount that sits on the pass. side of the motor under the crank pulley? Confucius say what?
  2. #2 Re: Collapsed lifter (Maybe)
    SE Level Member bjermane1's Avatar
    Nesbit, MS
    Quote Originally Posted by FordMan77 View Post
    Part connecting dog bone to engine. Sorry if I have terms wrong
    2004 Grand Prix GT - fwi, custom flowmaster exhaust, DHP PCM
    *Coming Soon* - 1.9 Roller Rockers, 105# Valve Springs, Top Swap (from gtp), Then dropping the pulley size
  3. #3 Re: Collapsed lifter (Maybe)
    St. Louis
    Ah, its the aluminum mount that the dogbone attaches to on the pass. side. Common area to crack. No, this would not affect the lifters but does need to be replaced.
    If you can't find a used one at a JY then I may have a good one laying around I could sell. IIRC, there is a year(s) that had a steel mount there that may be better to use.
  1. xp cam and 105 lifter question
    By copperpacecar in forum General Tech Discussion
    Last Post: 03-20-2011, 07:13 PM
  2. ticking lifter
    By ionroller in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2010, 12:21 PM
  3. Lifter tick?
    By My GTP 97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2010, 01:03 PM
  4. Lifter replacement
    By kfish in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2009, 05:35 PM
  5. Bad Lifter?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 10:03 PM
