Thread: Car smells of gas when stopped, net said charcoal canister??
Results 1 to 13 of 13
  1. #1 Car smells of gas when stopped, net said charcoal canister??
    SE Level Member blbikerood's Avatar
    Missouri Bootheel
    Where is it, can it be cleaned, replaced. Bypassed. What gives. Thanks for any help ahead of time!
  2. #2 Re: Car smells of gas when stopped, net said charcoal canister??
    Omaha, NE
    EVAP canister is what they mean. Unplug the EVAP silinoid and see if it gets worse. If not you may wanna get that replaced or delete it.
  3. #3 Re: Car smells of gas when stopped, net said charcoal canister??
    Oct 2008
    Calgary, Alberta
    Also check the fuel rails connection as the o-rings in them can get old and fail, leaving a pool of fuel on the supercharger.
  4. #4 Re: Car smells of gas when stopped, net said charcoal canister??
    Houston
    Charcoal canister? You drivin a GP or a train?...jus playin. I believe that it is located by or above the gas tank. But I'd check what 98gtp said. Its an easy inspection. Check the rails right here ↓
  5. #5 Re: Car smells of gas when stopped, net said charcoal canister??
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    o rings on the injectors. i actually had the gas smell as well mine came from the connection above the s/c the oring was cracked if u have a tooth pick u can pick it out take the old one in and get a new one
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  6. #6 Re: Car smells of gas when stopped, net said charcoal canister??
    Lift hood and inspect ....before you have a fire.
  7. #7 Re: Car smells of gas when stopped, net said charcoal canister??
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Agreed! These cars are famous for engine fires. I bought a 99 GTP a few months back in great shape and it had an engine fire right in that area. The car was totalled even though we put the fire out pretty quickly. The insurance company thinks it was a faulty repair on the valve cover gasket recall but the fuel rails look exactly where the fire burned a hole through the plastic super charger cover. It all worked out good though becuase we got a 2002 just like it in better shape with less miles
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  8. #8 Re: Car smells of gas when stopped, net said charcoal canister??
    Missouri Bootheel
    Well I just have the standard 3.8. Not a supercharged car. are they still famous for fires??
  9. #9 Re: Car smells of gas when stopped, net said charcoal canister??
  10. #10 Re: Car smells of gas when stopped, net said charcoal canister??
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    grand prixs are known to spontaneously combust.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  11. #11 Re: Car smells of gas when stopped, net said charcoal canister??
    With the piss poor drivetrain mounting, the whole thing is constantly moving back and forth. The nylon aka plastic like fuel lines do well, but over a lot of years, they seem to pop pinhole leaks.
    Evap issues shouldn't be enough to smell fuel from. A leak of fuel on a warm engine though...that's why I say, start looking, sniffin and feeling around.
  12. #12 Re: Car smells of gas when stopped, net said charcoal canister??
    Missouri Bootheel
    Hopin to find this problem this weekend!
  13. #13 Re: Car smells of gas when stopped, net said charcoal canister??
    Gas smells aren't something to screw with. I hope you aren't driving it. When the chance of blowing up or catching fire are in play as they are with the gas smell...you aren't only talking about the car, you are talking about your life potentially.
    I'm not one to blow stuff out of proportion w/o cause. Merely want to ensure you realize the potential of the situation could be bad.
  1. 04 gtp canister fit in an 01 GT?
    By ChrisGTT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2010, 05:23 PM
  2. Smells like FIre
    By chitownballer8908 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2009, 07:06 PM
  3. Racetronix Fuel pump canister install questions...
    By Iron Indian in forum General Tech Discussion
    Last Post: 05-18-2009, 12:11 AM
