Thread: Throttle body
Results 1 to 20 of 52
  1. #1 Re: Throttle body
    Oct 2008
    Calgary, Alberta
    Go to zzperformance website under:
    -air intake and fuel delivery
    The images for the ported maf sensor is shown with the ported tb's
    Do a search for the following on there site:
    Pontiac GTP High Velocity Throttle Body Info
    You will link to an article with images of the newer maf hump and older maf splitter, they only stage 2 port the newer maf hump although others have done both. This will require the computer be tuned fot the larger area around the mass air flow meter. (zzp suggests this for 12 second 1/4 mile cars)
    I would suggest seing if a supercharged tb from the same era 97-98 or 99-03 has the same opening around the mass air sensor, negating the need for a tune, allowing you the benefit from the ported t/b blade.
  2. #2 Re: Throttle body
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by 98gtp View Post
    GT Throttle body= .021 grams a sec of air
    GTP TB=.024 grams a sec of air. Tune will be needed
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  1. ls1 throttle body
    By taman86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2011, 05:33 PM
  2. N* Throttle Body
    By footballplaya3k in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2010, 10:33 AM
  3. LS1 Throttle Body
    By JbrownGTP in forum General Tech Discussion
    Last Post: 07-05-2009, 07:14 PM
