Thread: How to wash the engine?
Results 1 to 17 of 17
  1. #1 How to wash the engine?
    GTP Level Member apierce1289's Avatar
    United States
    What stuff do i need and how to protect it while washing the engine? I want her really clean so if theres any good engine cleaner i can pick up let me know, im gonna go to my local do it your self pressure wash place
  2. #2 Re: How to wash the engine?
    Self serve car wash...dont spray electrical ****...
    Then tire FOAM everything...let is sit for about 10 minutes...then wipe off whatever is left over.
    Done.
  3. #3 Re: How to wash the engine?
    United States
    Ok can you be more descriptive I really don't wanna screw it up.
  4. #4 Re: How to wash the engine?
    St. Louis
    Cover the coil packs, TB, MAF, MAP sensor, Trans. connector, and anything else electrical comes to mind. Just take a look at the motor and cover anything you can that has an electrical connection. Or just don't spray those w/ water and you should be good to go.
  5. #5 Re: How to wash the engine?
    Wow...I just spray everything down with a hose, its all made to get wet guys.
  6. #6 Re: How to wash the engine?
    yea i spray everything thing with grease lighting and let it sit and then wash it all off...not covering anything up
  7. #7 Re: How to wash the engine?
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Only thing I ever cover up is PCM
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  8. #8 Re: How to wash the engine?
    Jul 2008
    sumter,south carolina
    only thing i cover is my cone air filter... ive gotten the coils wet before and it misfired like crazy for a few minutes til it dried out.
    02 GTP with mods 05 GP for DD
  9. #9 Re: How to wash the engine?
    Feb 2010
    N.C.
    or you could just hit all the electrical connectors with a shot of WD40 after washing it off. It's primary purpose is to displace water. Wipe up excess.....your done.
    Most people spend their entire lives wondering if they made a difference in the world; Marines don't have that problem.
    -President Ronald Regan
  10. #10 Re: How to wash the engine?
  11. #11 Re: How to wash the engine?
    Never Never Land
    Quote Originally Posted by DrunkieTheBear View Post
    Ya I just spray the shiz out of everything but I dont spray directly at the sensors and other electrical stuff....i spray over them from a little bit futher away.
  12. #12 Re: How to wash the engine?
    Donating Users zx7r4u2nv's Avatar
    butler, pa
    i purchase 2 cans of Brite kleen engine cleaner.
    Drive to car wash.
    Sit there for a little to let the engine cool down.
    Spray everything with the engine cleaner
    Wait 10 minutes for cleaner to work
    Pull into car wash and spray the crap out of everything. (i do not hold back for anything)
    After driving a little and engine is dry a spray tore foam shine all over(try to miss belt otherwise may slip or squeel) and wipe off excess
    I do this every spring to every car i have owned for the past 10 years.
    No problems ever and engine looks sweet
  13. #13 Re: How to wash the engine?
    If you haven't done some maintenance, do it. Plug wires are probably the biggest issue when washing a motor.
    I bougth my car at 161K, and powerwashed it 3 times. Don't pummel gasket areas and you are fine. Don't spray electrical stuff directly and when you wet the belt..expect it to make some noise.
  14. #14 Re: How to wash the engine?
    step 1) close hood
    step 2) forget you ever opened the hood
  15. #15 Re: How to wash the engine?
    step 1) close hood
    Step 3) Drive a Stubaru
  16. #16 Re: How to wash the engine?
  17. #17 Re: How to wash the engine?
    I use foamy engine brite brand or simple green. The only two things I cover up in my engine bay are the cone filter/pcm and alternator. I usually spray the sh1t out of the engine and let the stuff sit for like 10 minutes or so. Any heavy grease I tend to use a rag or even a wire brush to help get the build up off. Then I pressure wash it all,use my air hose to blow dry the water out of the crevices. Start the car and let it dry the rest of the way.
    Snorlax strikes again.
  1. bad car wash!!!
    By cobbrobinson in forum Introductions/Noob Questions
    Last Post: 01-10-2011, 03:02 AM
  2. After a wash and wax
    By Louie3 in forum Visual/Body Modifications
    Last Post: 06-27-2010, 03:21 PM
  3. a little wash and a little wax
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 06-08-2009, 03:54 PM
  4. Wased my engine at the car wash 2 weeks ago, still have miss at idle.
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-07-2009, 05:59 PM
