Ok, I have figured out that the failed e-check was more than likely because of the converter. I got the car started and pulled it from outback into our muffler shop and raised it up, somebody that owned it prior had cut the converter off knocked the inside of it out and welded it back on.
The other motor I had found fell through so now I'm back to looking and found some L26's that are pretty cheap and low miles compared to the L36. Checked a couple of days ago and there weren't any L26's now there's about 10 of them, go figure.
Now I seen I had to change the upper intake from the L36 to the L26 but from what I have been reading it seems like every L36 that gets a rod knock is caused by the upper intake cracking where the EGR tube comes through dumping coolant into the lower intake which drains to the pan and causes it to spin a bearing. I am assuming that's what happened to this motor so I don't want to change the upper intake onto a nice L26 to have it ruin that one. Is there an easy way to check the upper for the crack? Even if I have to get another L36 upper used I don't think I would want to put it on the L26 and have it crack in 10k miles and ruin the L26?
