also since you are dropping in a l26 why not just drop in a l67 its a straight drop in u just need a retuned pcm for the diff gear ratio in the transmission but its only like 100 bucks
No on the L67 cause the the motor would cost more, plus the cost of the re-tune of the pcm, and considering its a car for my girlfriend who is also the one paying for all of this, its not really needed. If I was doing the car for me I'd do an L67 but alas its for her and needs to be done as cheaply as possible but yet be reliable enough to last hence why I would like to keep the Aluminum intake from the L26.
You went right into my next question with the u bend pipe, because I was looking up the converters and we don't have a catco listing for a universal converter for an 05 and its a different direct fit number would the pipe that has the flex unit in it for the l36 that bolts to the manifold and comes down underneath the car bolt to the manifold on the l26? and I'm confused as to how you would eliminate the u pipe because it connects both manifolds? unless I'm thinking about this the wrong way?
edit: the only way I'm thinking of eliminating the u pipe would be to run true duals down off each manifold but then I would need two converters to pass e-check, one each bank.
edit 2: Also, what about the flywheel/flexplate and bolting the L26 to the transmission that came with my L36 car?
im not sure about the flexplate butthe l36 one should fit also the ubend is the part of the downpipe where iy goes from round pipe to like a flatened oveal where the 02 sensor mounts that part is very restrictive and should be replaced with a staight section of pipe the part u were thinking of is the crossover
Ok, now I know what part you are talking about, don't know if I will worry about that cause my main concern is getting the car running so she will have a car to drive.
I read in one thread that the rear exhaust manifold will need swapped from the L36 to the L26 for the exhaust to bolt up correctly but I only seen it in one thread, is that also correct?
And if someone could confirm about the L26 bolting to the transmission that came with the L36 that would be great.
I just want to have everything figured out before I go buy an L26 and then all of a sudden there's a major obstacle that I was unaware of, so far it seems like some things need switched over which isn't bad the thing that has me really worried is bolting to the transmission.
i am 110% sure the transmission bolts up i am not sure about the rear manifols but your l36 one will fit so no problem there
When you say the L36 one will fit I'm not sure what you mean?
The L36 exhaust will bolt to the L26 Manifold or the rear L36 manifold will bolt to the L26 head and crossover?
And thank you for the info on the transmission.
