Thread: Installing the Coolant Temperature Sensor Problems
Results 1 to 20 of 24
  1. #1 Installing the Coolant Temperature Sensor Problems
    Texas
    Hey,
    So, as I was installing the sensor, I apparently put too much force behind it and cracked what I thought was the thermostat housing, but after going to autozone to get the part, it doesn't look anything like what I cracked.
    It is cracked right under where the sensor screws in on a 2000 Grand Prix 3.8. Any help on what this part is called? Tips on repairing/replacing it, etc would be much appreciated
    Thanks
  2. #2 Re: Installing the Coolant Temperature Sensor Problems
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    lower intake manifold
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  3. #3 Re: Installing the Coolant Temperature Sensor Problems
    Texas
    This is not an exact picture of what the one on my car looks like, but gives you an idea of what I'm talking about exactly.
    http://images.yuku.com/image/jpeg/20...c391c044bf.jpg
    That metal housing that the sensor is screwed into, and the thermostat goes into the top, that is the part that is actually cracked. Doesn't look like the lower intake manifold to me, but is it?
    Thanks for the reply by the way
  4. #4 Re: Installing the Coolant Temperature Sensor Problems
    Texas
    Also, is that something that can be replaced by an amateur mechanic, or have I really screwed this thing up?
  5. #5 Re: Installing the Coolant Temperature Sensor Problems
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    that is your lim the sensor and the t stat house bolt onto it so u would need a lim if u want one i have one from a 2001 let me know
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  6. #6 Re: Installing the Coolant Temperature Sensor Problems
    Texas
    lim being the lower intake manifold? How hard/involved is that to replace?
  7. #7 Re: Installing the Coolant Temperature Sensor Problems
    here is a link to a thread it has a how to video watch it http://www.grandprixforums.net/lim_lifter_video.php
    sold 97 GTP stock
  8. #8 Re: Installing the Coolant Temperature Sensor Problems
    Texas
    Oh jesus....All for a 15 dollar sensor...GRRRR Thanks for the video!
  9. #9 Re: Installing the Coolant Temperature Sensor Problems
    Texas
    It is just a small crack, but it is big enough for coolant to come out of...Do you think there is anyway to just seal it?
  10. #10 Re: Installing the Coolant Temperature Sensor Problems
    Grand Rapids, MI
    i'd go ahead and just replace the LIM, especially if you haven't already done the gaskets you might as well just get another LIM and put metal gaskets.
    dont feel bad though, i strip so many bolts and threads because i wanna put that finishing touch on every bolt. good luck.
  11. #11 Re: Installing the Coolant Temperature Sensor Problems
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    JB weld will work.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  12. #12 Re: Installing the Coolant Temperature Sensor Problems
    Quote Originally Posted by 01gpgt01 View Post
    JB weld will work.
    this but it all depends on how long u wanna keep the car if it was mee i would do it proper and just replace the intake but if u want a cheap fix and dont plan on keeping the car long just jb weld it
    sold 97 GTP stock
  13. #13 Re: Installing the Coolant Temperature Sensor Problems
    Texas
    hmmm that video does make the lim look like a detailed, but somewhat simple task...On the other hand, my car is in pretty bad shape as it is anyway. It's a 2000 with over a 180k miles on it. It leaks all over the place and I'm constantly having to do repairs on it. If JB Welds would hold just long enough to replace the car, I may just do that. I was worried that there may be too much pressure in that intake for jb welds to hold? Have y'all ever done this successfully?
  14. #14 Re: Installing the Coolant Temperature Sensor Problems
    Texas
    One other question...Where can I find a lim? I've called around to numerous shops that generally have everything, and all they can get is the upper
  15. #15 Re: Installing the Coolant Temperature Sensor Problems
    junkyard or used from someone on here is your best bet. honestly, youll find a used one on here from someone for damn near nothing. put up a WTB thread in the WTB section and im sure youll have one within a week.
  16. #16 Re: Installing the Coolant Temperature Sensor Problems
    I'm having a tough time believing you cracked an LIM with a brass sensor. The brass should have given and stripped before the LIM cracked. Plus it's in such a place that I'm surprised you can see a crack.
    How about a picture of the actual crack in your manifold? Just to ensure that we are all on teh same page and you pulled off the nearly impossible.
  17. #17 Re: Installing the Coolant Temperature Sensor Problems
    Texas
    Well, a picture would be next to impossible due to the location, because I had to use a flexible mirror (kinda like a dentist uses) to look under where the sensor screws into. Sure as snot, there is about a 1 1/2 inch crack running from the sensor across the manifold. I'm just as shocked as you are. I was going to JB Weld it, but I just discovered how big the crack is...With as old as the car is, and with all the other problems, I'm thinking the only thing to do here that is feasible is to just get a new one.
  18. #18 Re: Installing the Coolant Temperature Sensor Problems
    Depending on the prices you are seeing.. holler. I've got three on the shelf.
  19. #19 Re: Installing the Coolant Temperature Sensor Problems
    Texas
    How much?
  20. #20 Re: Installing the Coolant Temperature Sensor Problems
    Shipping plus $10
  1. Replacing coolant temperature sensor
    By vertebrate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2013, 01:43 AM
  2. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  3. Temperature Problems
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-19-2010, 10:55 AM
  4. o-ring for temperature sensor?
    By nlinesk8s in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-04-2010, 04:06 PM
  5. coolant sensor
    By 1LoudGrandPrix in forum General Tech Discussion
    Last Post: 12-30-2009, 07:56 PM
