Thread: PO301 code. Did my research and just need a little guidance.
Results 1 to 20 of 41
Threaded View
  1. #14 Re: PO301 code. Did my research and just need a little guidance.
    Kansas
    I suppose that is the same thing. I have a "service engine soon" light that flashes when it happens.
    Found this using google.
    http://repairpal.com/OBD-II-Code-P0301
    I might just take it to a mechanic to have them look at the car.
    When the code P0301 is set in the Power Train Computer, it means that the Misfire Monitor has detected more than a 2 percent variance in RPM between the firing of any two (or more) cylinders in the firing order. The Misfire Monitor constantly checks the rotational speed of the Crankshaft by counting the pulses of the Crankshaft Sensor. The Monitor wants to see a smooth increase or decrease in engine RPM. If there are jerky and sudden changes in the speed output of the Crankshaft Sensor, the Misfire Monitor begins to count the RPM increase (or lack thereof) contributed by each cylinder. If it varies beyond 2 percent, the Monitor will set a P0301 code and illuminate the Check Engine Light. If there is more than a 10 percent variance, the Check Engine Light will blink or pulse in a steady manner to indicate that a harmful Catalytic Converter misfire is occurring.
  1. RPO code tag
    By Wicked13 in forum General Tech Discussion
    Last Post: 05-04-2010, 07:34 PM
  2. I got a code!!!???
    By justwhisen in forum General Tech Discussion
    Last Post: 04-14-2010, 07:22 PM
  3. 2006 GP GT - Modding research
    By GeeBee in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2009, 02:34 PM
  4. Need help and guidance
    By elmac in forum General Tech Discussion
    Last Post: 03-01-2009, 12:52 AM
  5. Transmission repair guidance
    By cwgruv3 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2009, 04:21 PM
