Thread: rattle at idle
Results 1 to 6 of 6
  1. #1 rattle at idle
    Donating Users
    Nashville, TN
    My wife's 2000 GT (non turbo) has a rattle at idle and it appears to come from the tensioner pully. I used a stethascope (sp) to find the location of the noise. I've replace the pully, but the rattle didn't go away. Does anyone have a suggestion of what to do next?
  2. #2 Re: rattle at idle
    St. Louis
    Try removing the belt and spinning/wiggling all the pullies by hand and see what rattles. You may find that the alt. is rattling causing the sound to resonate down into the bracket, which is where the tensioner lives. Could also be a waterpump.
    Worse case scenario you could start it with the belt off for a BRIEF moment and see if the rattle disappears. If it doesn't then you're rattle is something in the motor that is not turned by the belt (ie- lifter, rocker, etc...).
  3. #3 Re: rattle at idle
  4. #4 Re: rattle at idle
    Donating Users
    Nashville, TN
    Thanks for the replies. I did try it without the belt and didn't hear the noise, but I can hear a squeal from the alternator when the temp is cold and the engine first starts. All of the bearings turn smoothly. The tensioner appears to have good tension and isn't loose.
    I'll pull the alternator apart to see if I can find a bad bearing.
  5. #5 Re: rattle at idle
    Northern New York
    dont...just buy new if you think thats where your noise is comming from
    '03 Grand Prix SE Nice n Slow, but I'll race you in the snow! (Current)
    '97 Grand Am 2.4 217,XXX mi (Sold)
    '00 Grand Prix SE (Deceased)
  6. #6 Re: rattle at idle
    Donating Users
    Nashville, TN
    Problem solved! The belt tensioner was the problem. I used a Gates tensioner and it was exactly the same as the original one. It even was made by the same company in Canada.
  1. Won't idle; missing above idle if you can get it started
    By jrece in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2011, 11:24 PM
  2. HUD Rattle
    By mseefried in forum General Tech Discussion
    Last Post: 10-09-2010, 11:53 AM
  3. Rapping/Rattle at Idle, goes away when revving
    By hoont79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2010, 05:25 AM
  4. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
