Thread: engine missing, codes aren't right!
Results 1 to 6 of 6
  1. #1 engine missing, codes aren't right!
    Northern Vermont
    I got a cylinder #3 misfire OBD code this past summer,was getting missing under acceleration with a jumpy tachometer, and I changed the coil pack, put in new spark plug but not the s.p. wire, because it looked okay. Problem went away....for a week.
    I did the night time firefly visual test on the wires. No arcing, so I assume they are still good? Or is there no way to test them for good/bad?
    Now I am getting missing for the first 20 seconds of cold start-up, and under acceleration, the dash flashed the service engine soon light 3 times and then stopped when I stopped provoking the problem.
    Thanks for all your replies and troubleshooting advice.
  2. #2 Re: engine missing, codes aren't right!
    Maybe try putting a new wire on it...just for S&G's
  3. #3 Re: engine missing, codes aren't right!
    Portland Oregon
    Swap the wire with another one and see if the miss follows the wire
  4. #4 Re: engine missing, codes aren't right!
    Northern Vermont
    Update: I went to Advance auto, and did a spark plug wire test, which was to spray with a spray bottle over a running engine to see if the wires were arcing. No arcs!
    No codes appearing at this point.
    I get the smell of partially burned gas fumes coming into the cabin when I hop on the gas pedal 1/2 way or more.
    Some other things come to mind, but I have no confirmation on if they are going bad or not:
    How many of you have had to change out a crank position sensor or ECU ?
  5. #5 Re: engine missing, codes aren't right!
    Charles City, IA
    Crank sensor does not control fueling. and the pcm would not cause you to run rich, Hook a scanner up to the car and have someone take a look at it.
    SMGPFC Two Nipple General
  6. #6 Re: engine missing, codes aren't right!
    Northern Vermont
    I have an OBD code scanner, and nothing comes up on it. I may try my "elm 327" USB interface that works with OBD for my laptop and see if any sensor starts acting up under load.
    I have the scantool.net software that is considered freeware, but does anyone have the upgraded software with data logging and graphing? Which one, and how do you like it? I want to get a good diagnostic software platform.
  1. engine missing and bucking at operating temp
    By jkirkwo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-18-2011, 11:22 PM
  2. Have 2 engine codes
    By GAFF in forum General Tech Discussion
    Last Post: 02-15-2011, 03:35 PM
  3. Engine codes
    By postalizer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-10-2010, 10:20 AM
  4. 97 GTP engine codes
    By willy4x4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 12:31 PM
  5. Missing an engine in the W-Body Tech forum
    By RareGMFan in forum Forum Bugs/Suggestions
    Last Post: 12-16-2008, 11:18 AM
