Thread: Burning smell from engine but no smoke?
Results 1 to 9 of 9
  1. #1 Re: Burning smell from engine but no smoke?
    St. Louis
    What does it smell like? Oil? Coolant (sweet smell)? Does it seem to smell after you brake/come to a stop quickly?
    I'd be willing to bet that the valve covers are leaking oil (especially the front) and is being burned off by the manifolds. Look under the front valve cover where the plug wire guide is and see if it looks wet/black. If so, then the cover is leaking.
    If you replace both valve covers then be sure to install new grommets as well. Fel-Pro sells a good set of gaskets/grommets for this.
  2. #2 Re: Burning smell from engine but no smoke?
    Houston
    Quote Originally Posted by FordMan77 View Post
    I agree...my car was recalled for that exact reason. I didnt have any leaks but there were apparently enough out there that did, for them to send out a recall.
  1. Getting that burning smell
    By Hockeytown19 in forum General Tech Discussion
    Last Post: 06-10-2010, 02:04 PM
  2. burning sort of smell
    By chuy09 in forum General Tech Discussion
    Last Post: 10-18-2009, 06:43 PM
  3. burning smell
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 09:42 AM
  4. Heated seats + Burning Smell?
    By xerxescct in forum General Tech Discussion
    Last Post: 01-25-2009, 11:31 PM
  5. Burning Oil Smell
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2008, 01:07 PM
