Thread: Blown motor? Head gasket? HELP PLEASE!!!
Results 1 to 20 of 30
  1. #1 Blown motor? Head gasket? HELP PLEASE!!!
    SE Level Member fpgt17's Avatar
    Grand Rapids
    Okay so my 1999 Grand Prix which is very well taken care of and in great shape is having some major problems.I started the car last week and it fired up perfect like always and then two minutes into it running (warming up) it started chugging as if a coil went out. I immediately shut my car off. I then tested the coils, ICM, changed plugs (they were shot), tested fuel pressure and was running just over 50PSI. All looked and tested great. Today i then decided to pressure test/ leak lease my cylinders (was affraid to at first). I have 150psi on all the back cylinders, 150psi on one in the front, 90psi on another and ZEROOOO on the front middle one!!!!! When i did the leak down test on the cylinder with zero compression it was at 100% leakage. I cant tell where it is going.
    Heres what i have come up with/ been told.....
    - Blown head gasket (but no coolant in oil or oil in coolant) Maybe didn't run long enough to get any in tho.... But usually with a blown head gasket i at least get more than zero compression!
    - Blew a hole in my piston and that's why i have zero.
    - crank sensor. (Off time and valves are open when shouldn't be and its letting air escape? idk......
    HELP!!!! let me know what you guys think! THANKS!
  2. #2 Re: Blown motor? Head gasket? HELP PLEASE!!!
    crank sensor wouldnt force a valve to open.
    timing is set mechanically and is non adjustable.
  3. #3 Re: Blown motor? Head gasket? HELP PLEASE!!!
    Charles City, IA
    Open your oil fill cap and see if you can here the air then.
    SMGPFC Two Nipple General
  4. #4 Re: Blown motor? Head gasket? HELP PLEASE!!!
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    01GTP is on the right track. Re-do the cylinder leak down test. Check the intake plenum, pull the oil fill cap and listen, the dipstick tube and listen, listen to the tail pipe (sign of a valve hung open or a burnt valve), check the rad for any signs of bubbles. Use a stethiscope and probe anythign and everything, especially down the dipstick tube.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  5. #5 Re: Blown motor? Head gasket? HELP PLEASE!!!
    Grand Rapids
    Well i retested the front three after i did the leak down test.... Now the front three are all giving me ZERO! Could it be possible that when i pressurized the front to do the leak down test it made the head gasket go out more.... i am leaning twords it being that now. I don't feel any air coming from the oil filler cap or exhaust. But there is no way all the front valves could be off giving me a compression of zero on three different cylinders right?
    Man my gp is not making me happy.....
    Thanks for the reply's tho guys! helps allot!!!!
  6. #6 Re: Blown motor? Head gasket? HELP PLEASE!!!
    Grand Rapids
    I just dont see how the headgasket or valves could go bad in 2 minutes of running it. Plus is was running perfectly fine the night before.... but i was told that the CPS wouldnt give me zero compression tho. The piston and rings will still create the seal.... AHHH idk What does everyone think?
  7. #7 Re: Blown motor? Head gasket? HELP PLEASE!!!
    Charles City, IA
    How are you doing to compression test?
  8. #8 Re: Blown motor? Head gasket? HELP PLEASE!!!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Are you opening the throttle blade wot when your doing it? Are you only pulling the plug for that cylinder? Is the engine up to operating temp?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  9. #9 Re: Blown motor? Head gasket? HELP PLEASE!!!
    Ontario, Canada
    When doing a compression test, you need to have ALL the plugs out, and the throttle at WOT while cranking. Test one cylinder at a time, and record your results. The engine doesnt necessarily have to be at operating temperature, makes it a little hard to do without burning yourself a few times while installing the test hose.
    The other thing I suspect is the schrader valve in your compression tester is acting up. Not an uncommon thing. Pull the schrader valve out and make sure its working properly. Replace it if necessary. Its the same schrader valve that your tire valve stem uses. You could borrow one from a valve stem if you dont have spares. Generally a small flat screwdriver will remove the schraders if you dont have a valve core (schrader) tool.
    Hope this sheds some light.
    Jay
  10. #10 Re: Blown motor? Head gasket? HELP PLEASE!!!
    Ontario, Canada
    Another thing, just to be sure your doing it right...we dont all know eachothers mechanical abilities, and as a diesel mechanic I like to help out where I can..
    anywho, when you were doing your cylinder leakdown test, did you have each cylinder at TDC (Top Dead Center) on the compression stroke while testing? If not, you will most deff get a zero reading for that cylinder.
    Jay
  11. #11 Re: Blown motor? Head gasket? HELP PLEASE!!!
    you should also dump a little oil into the cylinder just to help seal similarly to how it would be when the car is running.
  12. #12 Re: Blown motor? Head gasket? HELP PLEASE!!!
    The oil is a test to see if your rings are gone.
  13. #13 Re: Blown motor? Head gasket? HELP PLEASE!!!
  14. #14 Re: Blown motor? Head gasket? HELP PLEASE!!!
    Grand Rapids
    Well i quess i was doing it wrong. Its been a while since the last time i had to do a compression test. I had all the plugs in and only took out the one that i was putting the test hose in. So the other five were in while i did the test.... Also idk if it was at TDC. i am not the best with testing motors/ figuring things out but i know how to fix allot of it. How do i make sure/ put it at tdc. Last time i did that the motor was out of the car and i could see the piston heads and i could turn the crank.....
  15. #15 Re: Blown motor? Head gasket? HELP PLEASE!!!
    Check your compression tester. I've done quick tests with all plugs but the one, heck even let the car start.... IT's not the right way, but to test for some compression, it works.
    There's no understandable way that you lost two cylinders during testing. Taht's why I suspect the tester.
  16. #16 Re: Blown motor? Head gasket? HELP PLEASE!!!
    Grand Rapids
    Well the tester is brand new. I have zero compression on the front three cylinders. I also did a leak down test on the front three which were 100% leakage......So i dont think its the tester. Both brand new testers were saying zero for the front three. But i had the rest of the plugs in and the throttle body was not open. I want to re-try it the "right way"
  17. #17 Re: Blown motor? Head gasket? HELP PLEASE!!!
    Now there's two compression testers or one compression, one leakdown?
    Here's what I'm seeing. A newer guy, that hasn't had time on the forums to see how nearly indestructible these factory head gaskets are. Out of a million of these motors, I'd be surprised to see more than 1 HG issue.
    Popped pistons.. heck..that's common, but not on 3 cylinders.
  18. #18 Re: Blown motor? Head gasket? HELP PLEASE!!!
    Grand Rapids
    Yes i am new on this forum and know the HG are very strong and that is why i am making sure everything is right before it tear into it....
    There is one compression tester, one leak down cylinder tester. Both bought new.
    I did the test without the plugs out and throttle not open. Gotta re-test it with all the plugs out and throttle open.
    Also i was told that it could be a CPS (Crank Position Sensor) Or even timing off.
    Could either of those cause zero compression? i know they can give you less compression but idk about zero..... like you said these hg's are very strong and i would not blow out three pistons at once. I mean it only ran for 2 min... didn't overheat and wasn't even warmed up. It just started shaking after 2 min like i lost a coil. But all fuel and spark tested good.
  19. #19 Re: Blown motor? Head gasket? HELP PLEASE!!!
    timing is set mechanically.
    It doesnt vary at all unless the chain skipped a gear.
    are you testing at TDC?
  20. #20 Re: Blown motor? Head gasket? HELP PLEASE!!!
    Grand Rapids
    Dont really know how to test at tdc.... Only done that when engine was out of car and could see the pistons..... well if timing couldnt do that and neither could my CPS....... wouldnt that lean twords my head gasket? idk what else to check.....
  1. Cars with blown head gaskets
    By GAFF in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-09-2010, 08:43 AM
  2. Blown head gasket?
    By tjhgtp86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2010, 04:01 AM
  3. low, very low oil. blown head gasket or something else?
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 01-04-2010, 03:51 PM
  4. blown head gasket
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-09-2009, 12:18 AM
  5. Possible Blown Head Gasket
    By Blk99GpGt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-09-2009, 12:40 PM
