Thread: upper intake
Results 1 to 9 of 9
  1. #1 upper intake
    Virginia
    My upper intake is leaking (anitfreeze) and I can see it coming out (under near ) throttle body. With 184k miles (is my intake warped) How would I be able to tell. Can i just remove the upper intake with the injectors still in place (unhooked)? How do i get the rail off the injectors? How do I bleed the fuel pressure.
    1. How do you get the fuel rails off the injectors?
    2. How do you bleed the fuel pressure?
    3. can I change the upper intake with fuel injectors still in place (fuel rail off)
    please help
    the car is leaking and I can see that its coming out the upper intake. The lower intake isnt leaking at all. This is my daily driver right now and I need it fixed fast.
    I priced the gasket (40.00)
    intake and gasket (121.00)
    please help
    It seems that I can pull the intake off with the fuel injectors still on the engine. Any pics
  2. #2 Re: upper intake
    Easiest way to do this is to remove 4 10mm nuts that hold teh rails down. Now wiggle and lift up. The injectors typically stay in the rail. There's no need to pull them out of the rail. No need to bleed pressure or anything else. Just set them off to the side when you get them off.
    Then you have access to the upper. The upper kit should come with the gasket and a lot of extras.
  3. #3 Re: upper intake
    if you wanna bleed of fuel pressure you can just take the fuel pump fuse out and then run the car till it dies out fro no fuel, should only take 2-3 seconds
  4. #4 Re: upper intake
    Virginia
    You are the man.....................thanks
  5. #5 Re: upper intake
    GT Level Member zipper's Avatar
    Dec 2008
    Shelby, MI
    1) You don't need to take the injectors off of the rail, like previously mentioned.
    2) The Fuel Pressure Regulator has a bleeder on it. Unscrew the cap, put a rag under it, and the push the bleeder in like you would a valve stem on a tire to let air out. This is the best way to remove pressure from the fuel rail. There will still be fuel in the rail, except there will be little to no pressure.
    3) Yes. You can see how to do it in the first few pics of my HV3 install page on Cardomain: http://www.cardomain.com/ride/205587...e-carlo/page-5
    Do some shopping for the UIM. That's too expensive. ZZP has there's for much cheaper, even with gaskets: ZZ Performance
    NA dyno: 222whp
    Novi 1000 dyno: 348whp
    Novi 2000 dyno: 372whp Best 1/4 mile: 13.2634@105.12mph
  6. #6 Re: upper intake
    Virginia
    so all I gotta do is.................undo the rail bolts (4) and pull up on the rail and the fuel injectors and the rail should come up.
  7. #7 Re: upper intake
    Dec 2008
    Shelby, MI
    That's it. Very easy.
    NA dyno: 222whp
  8. #8 Re: upper intake
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Sometimes they take a little force to get them out but just keep wiggling
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  9. #9 Re: upper intake
    Virginia
    thanks ....................
    im gonna do it in 2 days
  1. l26/l36 upper intake swap
    By GOINDEF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2017, 10:10 PM
  2. Upper Intake.. =(
    By Pshnmeawy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2010, 10:38 PM
  3. Upper Intake Replacement-Which Is Best?
    By jsoluna in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-21-2010, 07:27 PM
