My upper intake is leaking (anitfreeze) and I can see it coming out (under near ) throttle body. With 184k miles (is my intake warped) How would I be able to tell. Can i just remove the upper intake with the injectors still in place (unhooked)? How do i get the rail off the injectors? How do I bleed the fuel pressure.
1. How do you get the fuel rails off the injectors?
2. How do you bleed the fuel pressure?
3. can I change the upper intake with fuel injectors still in place (fuel rail off)
please help
the car is leaking and I can see that its coming out the upper intake. The lower intake isnt leaking at all. This is my daily driver right now and I need it fixed fast.
I priced the gasket (40.00)
intake and gasket (121.00)
please help
It seems that I can pull the intake off with the fuel injectors still on the engine. Any pics
