Quote Originally Posted by HNorm View Post
Thanks for the replys. The battery is fully charged, the engine turns over very easily. I changed the wires only after the engine did not run, and I replaced the wires one wire at a time. No loose connections. When I try starting the car, at first it turns a couple revs and then I can here one or two cylinders fire, but does not start. After that it just turns with no additional cylinders firing. I checked the fuel pressure by the injectors, when I turn on the key I can hear the fuel pump run, the pressure reading got up to 50psi, however my pressure tester does not have a good seal at the test point. After a few seconds with the key on the fuel pump turns off and the pressure drops to zero. I checked all the fuel line fuses. IF I am getting a spark on one of the cylinders I didn't think to look at any other fuses. My thought is I may need to replace either the crank shaft sensor & or the cam sensor, however I am supprized no codes are being registered.
just changed my crank shaft sensor runs great now ,try it i just changed all kind of stuff and it was that all along !
