Thread: Help! Loping GT
Results 1 to 20 of 21
  1. #1 Help! Loping GT
    SE Level Member BlackNRedGT's Avatar
    Dec 2010
    Saint Joseph, MISERY
    So I have a 1999 grand prix GT and It has a few problems. I get real crummy gas mileage and it lopes all the time. When it's cold it runs fine but as it heats up it lopes after touching the gas a few times before it fines it's idle. I've thought vacuum leaks, MAF, or fuel pressure regulator,but I don't know. Anyone have some advice?
  2. #2 Re: Help! Loping GT
    Unplug the MAF...if that changes anything then you need a new one.
    Vacuum leak...spray carb cleaner around the motor when its running...if the idle changes then you've found your vacuum leak.
  3. #3 Re: Help! Loping GT
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Edit, Blue mirrored what i was typing.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: Help! Loping GT
    Iz psychic.
  5. #5 Re: Help! Loping GT
    Dec 2010
    Wait unplug the MAF while the cars running or off?
  6. #6 Re: Help! Loping GT
    While its running.
  7. #7 Re: Help! Loping GT
    Dec 2010
    So I unplugged the MAF sensor while it's running and nothing happened..
  8. #8 Re: Help! Loping GT
    Ok...so then the MAF is good...check for a vacuum leak with some carb cleaner while its running...do you have any check engine lights?
  9. #9 Re: Help! Loping GT
    Dec 2010
    I will go get some a look around with that
    And yes I do I scanned it and It came back as mass volume air low(or something like that cant remember fOr sure) and running lean in bank 1
  10. #10 Re: Help! Loping GT
  11. #11 Re: Help! Loping GT
    Dec 2010
    Alright I'll look around with carb cleaner and see what I find
  12. #12 Re: Help! Loping GT
    Anything most of the time bank one lean is 99.999999999999999% a vacuum leak...most of the time your factory lines and rubber "T" fittings around shot around the fuel rail, throttle body, lower intake manifold, upper intake...etc.
  13. #13 Re: Help! Loping GT
    Dec 2010
    Update*
    I sprayed with carb cleaner and found a leak. I replaced the vacuum fittings and t fittings. Turned the car on and it continued to lope> I then scanned the car again and had two different codes. I musta fixed the leak but now the codes both say MAF is bad... So new MAF?
  14. #14 Re: Help! Loping GT
    Kansas
    yes
    SOLD 1999 GT Silvermist TS
  15. #15 Re: Help! Loping GT
    Dec 2010
    Replaced the MAF and its perfect thamks for the help guys
  16. #16 Re: Help! Loping GT
    Funny thing here is I think we got lucky.
    When you unplugged the maf, you were destined to have a maf code.
  17. #17 Re: Help! Loping GT
    Dec 2010
    Dang if thats true I might have LOL
    Luckily everythings fine now runs like 5X better now
  18. #18 Re: Help! Loping GT
    GTP Level Member
    springfield IL
    i kinda have the same problem.......
    when i turn the car off, you hear woosh sound..?? is that a vac leak???
  19. #19 Re: Help! Loping GT
    intake?
  20. #20 Re: Help! Loping GT
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    my intake does the same thing its not a problem
