Hi, new to this forum.
Saw a similar thread topic to this but it seems to have gotten a bit off focus.
About 18 months ago I had the UIM replaced on my 2002 GP 3.8l Naturally Aspirated v6.
I was getting a low coolant light after driving on the highway for 5 min or so. The minute you slowed it went off.
The problem is back, and I am thinking the UIM was fine.. Oh well now.
So I have done some more playing. This time oddly after I refilled the overflow the light still is coming on at highway driving.
So today on the way to work, when the light came on I shifted to neutral. Light immediately went off. Put back in drive and it took another 3 to 5 minutes for the light to come back on. Once the light came on I again put in neutral but kept the RPM's up light stayed on. Took foot off the gas light went off. Back into drive no light about 3 to 5 minutes later light came on as I was exiting the freeway - coasting rpms were low below 1500 I shifted to N (little to no change in RPM) light immediately went off.
When I got to work the parking lot was to dark to see what level the coolant was at in the overflow bottle.
This behavior has been very consistent so I don't think it is a bad sensor.
A few things I don't know... Where is the low coolant sensor in this system.
Is it possible with engine roll (which is for-aft right) some line is getting pinched... eventually enough coolant is pumped at the restriction (increasing pressure) that the level seen at the sensor drops, once the engine roll comes off the line opens a bit and lets the coolant flow? Of course during coast down the engine roll would be in the opposite direction so not sure why the coast down part happened....
