Thread: Catalyst Under Threshold
Results 1 to 5 of 5
  1. #1 Catalyst Under Threshold
    SE Level Member Pontiac Warrior's Avatar
    Hudsonville
    I am having an issue with a code being triggered in my car and it causing the check engine light to come on. I know my catalytic converter isd good since it is a brand new Magnaflow high flow preformance cat from zzp. The guys at Advanced auto are telling me i may have an exhaust leak? Anyone experinced this and know for sure? Or am I having a problem because of the high flow cat? Any Help would be appreciated thanks guys!!!!
    Pontiac Warrior
  2. #2 Re: Catalyst Under Threshold
    Check for an exhaust leak, you'll be able to hear it.
    If there isn't one.
    Then its just the cat being a whore.
    They tend to do that if your tune is off.
  3. #3 Re: Catalyst Under Threshold
    Hudsonville
    I listened for a leak and yea there is one. If the leak being fixed doesnt help Would a tune up help the problem?
    Pontiac Warrior
  4. #4 Re: Catalyst Under Threshold
    a street tune with a wideband would fix it.
    Depending on what year your car is, you could run an O2 sim.
    Unsure if you have emissions and if this would effect that.
  5. #5 Re: Catalyst Under Threshold
    Who has emissions? Delete that EGR and Converter crap and never worry about it again.
  1. Catalyst Codes help
    By richiey13 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-11-2009, 05:33 PM
  2. p0420 Catalyst System Efficiency Below Threshold (Bank 1)
    By NaturallySmashed in forum General Tech Discussion
    Last Post: 08-12-2009, 01:05 PM
