Thread: Need urgent help, how to get water pump elbow out
Results 1 to 6 of 6
  1. #1 Need urgent help, how to get water pump elbow out
    Nov 2010
    Nashville TN
    Hi folks,
    I posted yesterday that I spotted coolant leakage on coolant elbow at LIM. I went ahead to replace it today. everyting went smoothly in terms of taking thing apart. However, I can't get the old elbow from water pump to tensioner assemlby out. Now, this dreaded elbow starts to leak.
    Any brilliant idea to remove this elbow.
    Thanks.
  2. #2 Re: Need urgent help, how to get water pump elbow out
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    What year is your Regal? I know 97-98 GP has a different alt bracket that has a cast elbow not the plastic ones.
  3. #3 Re: Need urgent help, how to get water pump elbow out
    utah
    you have to take most of the rotating side off. alt, hyrdralic tens...all that stuff. its like a 6 dollar part and a common issue....guess i misunderstood your question, pull like hell and it'll come out. or just break the damn thing since you need to replace it any how
  4. #4 Re: Need urgent help, how to get water pump elbow out
    Nov 2010
    Nashville TN
    Thank you all for the help. Finally got it done, no more coolant leakage and I can fall into asleep from now on.
  5. #5 Re: Need urgent help, how to get water pump elbow out
    Nov 2010
    Long Valley, NJ
    Hi I think I have the same problem, I have a leak that is coming from beneath the alt but is behind the water pump so I cant really see it.
    I have a 97 SE, and I bet its this elbow. What is it actually called so I can get a replacement?
  6. #6 Re: Need urgent help, how to get water pump elbow out
    Charles City, IA
    coolant elbow. You have a 3.8 right? the 3.1 and 3.4 do not have the elbows.
    SMGPFC Two Nipple General
  1. Water Pump
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2010, 10:19 PM
  2. Water pump issue
    By josemolina2008 in forum General Tech Discussion
    Last Post: 08-18-2010, 12:47 AM
  3. water pump
    By Ramondo411 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2009, 12:35 AM
  4. Water pump ?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 01:21 PM
  5. water-pump's possibly going out?
    By fst in forum General Tech Discussion
    Last Post: 09-02-2008, 08:49 PM
