Thread: 2001 GP 3800 Wont Idle without gas pedal
Results 1 to 20 of 20
  1. #1 2001 GP 3800 Wont Idle without gas pedal
    Nebraska
    like it says.. Every time i start this car it has very extended crank, when it does turnover it will not idle unless i keep it running myself. I have been trying to figure this out, any help would be appreciated. I have replaced the coil packs, new plugs, plug wires, fuel pressure reg, and map sensor. It has not resolved this issue. I did pull a vac hose and it does idle and runs great, but soon as i put the hose back on, the car dies instantly. Unplugging the IAC does not make a difference.
  2. #2 Re: 2001 GP 3800 Wont Idle without gas pedal
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    which vacuum hose did you pull?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  3. #3 Re: 2001 GP 3800 Wont Idle without gas pedal
    GTX Level Member cerick08GP's Avatar
    Quote Originally Posted by BlaZiNRaIgN View Post
    Sounds to me like your fuel pump resistor is bad. I just don’t get the whole vacuum hose thing though.
    Good luck
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: 2001 GP 3800 Wont Idle without gas pedal
    SE Level Member chev1988rolet's Avatar
    Jul 2010
    TX
    since the car wont stay on by itself or even turn on, and it only stays on when you either press pedal to give it more air or by pulling a vaccum line. It means that not enough air is getting into your engine. could be two things. you have a plugged up pcv valve or a bad IAC stuck in the extended position which means pintle is actually stuck on throttle body or carbon deposits on pintle causing it to be stuck not letting it open up to allow air into engine. 1. you can check pcv by removing it and shaking it. a good pcv will make a rattling sound. another way to check it is to see if you can actually blow air through it. 2. as far as the IAC, remove it and clean pintle with carb cleaner and also clean the hole where the pintle extends into (its about a 7/16 inch small hole. you can also check IAC by removing it but keeping it connected to harness and have a someone turn the key to the on position but not crank and see if the pintle moves. if it doesnt then that means the little motor inside of it is bad. Good luck
  5. #5 Re: 2001 GP 3800 Wont Idle without gas pedal
    Jan 1970
    Maquoketa, Iowa
    would go ahead and replace the vac lines. 26 bucks if a good cleaning of the iac doesn't work. Just because it idles without it doesn't rule a vac leak out.
  6. #6 Re: 2001 GP 3800 Wont Idle without gas pedal
    Nebraska
    Quote Originally Posted by Jakegday View Post
    Its the vacuum hose on the back of the manifold, the one the that is next to the brake booster.
  7. #7 Re: 2001 GP 3800 Wont Idle without gas pedal
    Nebraska
    Quote Originally Posted by chev1988rolet View Post
    Thanks for all of your help, i will check the PCV Valve, and check the IAC.
  8. #8 Re: 2001 GP 3800 Wont Idle without gas pedal
    Nebraska
    Quote Originally Posted by FoSHO99 View Post
    Where is a good place purchase the Vac lines? Just Napa? Thanks!
  9. #9 Re: 2001 GP 3800 Wont Idle without gas pedal
    Nebraska
    Quote Originally Posted by cerick08GP View Post
    Good luck
    Is there a way to check the resistor? Where is the location? Thanks!
  10. #10 Re: 2001 GP 3800 Wont Idle without gas pedal
    Jul 2010
    TX
    if it was fuel related then it would not start at all or stay on when you press the pedal. your giving it more air by pressing the pedal which achieves the correct air/fuel mixture to turn the engine on
  11. #11 Re: 2001 GP 3800 Wont Idle without gas pedal
    Willoughby, Ohio
    briefed thru this but i also say PCV is bad, had a similar problem last year
  12. #12 Re: 2001 GP 3800 Wont Idle without gas pedal
    http://www.grandprixforums.net/car-w...ing-37355.html
    This sound familar?
    If the bypass works, that means the resistor is bad. Or you could just break out the multi meter right away.
    Rocky Mountain Club Grand Prix
    2008GP
    2002GP||sold
  13. #13 Re: 2001 GP 3800 Wont Idle without gas pedal
    Michigan
    Does that bypass only work for gtp's? I have a 97 gt doing the same thing.
  14. #14 Re: 2001 GP 3800 Wont Idle without gas pedal
    Chicago, IL, USA
    You have a bad IAC solenoid, had it happen on three diff cars 5 times. It will not always set a SES light.
  15. #15 Re: 2001 GP 3800 Wont Idle without gas pedal
    Michigan
    Okay, where exactly is it located? I will try changing it out. I did notice too that once the car sits for a while after it will start up.
  16. #16 Re: 2001 GP 3800 Wont Idle without gas pedal
    SE Level Member Paintball0027's Avatar
    Jul 2010
    Michigan
    This problem just randomly happened to my 99' GT. Drove fine all day, went to the gym, came out an hour later, wouldn't start. Changed the MAP trying to see if that was it. No luck. Checked the forums on my phone, saw that people were talking about some fuel pump speed control relay and to bend something to test it. Opened up my fuse box, turns out I don't have that relay. So, where is this fuel pump resistor so I can try that next. Thanks.
    2007 Pontiac Grand Prix GXP - ZZP exhaust,1999 Pontiac Grand Prix GT -Falken Cinturato 828 tires,GMPP performance handling kit,oversized front sway bar, front strut tower brace, tubular trailing arms, spectre cold air, 180* drilled thermostat, ZZP Racing transmission with 3.29 gears, 4th gear hardened shaft, shortened dog bones.
  17. #17 Re: 2001 GP 3800 Wont Idle without gas pedal
    Donating Users 98GTPstat's Avatar
    Dec 2010
    livonia, Mi
    I have came across this and found it to be the throttlw postion sensor. Actually ive came across this a few times. Check your codes if you have any. Either tps sensor or iac Sensor both located on your throttle body
  18. #18 Re: 2001 GP 3800 Wont Idle without gas pedal
    SE Level Member Fritcr's Avatar
    Apr 2008
    Someone will correct me if I'm wrong but I think the 2 speed fuel pump is only on the GTP (supercharged) cars.
    Rob
  19. #19 Re: 2001 GP 3800 Wont Idle without gas pedal
    Michigan
    Quote Originally Posted by Fritcr View Post
    Rob
    Yes, only on the GTP...
    Okay so I changed my IAC valve, and it seemed to idle and run a lot better! Then I went to the store and when I came out, I had the same problem it would start then die immediately I had to keep the gas down to keep it running. Even then it was sputtering and a lot of smoke was coming outta the exhaust. I managed to start driving and I could put ti to the floor and it would sputter along at no more that 20mph.. I let off some and it sputtered up to about 30, then it seemed to clear up and ran fine again, I had all the power back all of a sudden... Stopped at a light and it was alright, I got on it some and it could break the wheels loose no problem...
    I have changed the IAC and the cam shaft positioning sensor so far... This is driving me crazy since it will run fine one monent and not at all/barely the next...
  20. #20 Re: 2001 GP 3800 Wont Idle without gas pedal
    Michigan
    Tps changed and I removed the EGR and cleaned it and put a new gasket on it... So I drive about 10 miles and go into the store about 5 mins later come out and start it up and it dies right away... I had to hold the gas down slightly to keep it running again.. I started driving down the road and it was sputtering real hard and then all of a sudden it cleared up again like usual and was fine the rest of the time... Stopped again got back in the car and it fired up no problems at all.. And its been fine on the last few times ive started it.. Just once in a while it seems it just wants to act up when I try to start it... ...???
    Someone told me it might have something to do with the temperature control sensor?? Said that it might be sending incorrect temperature readings and causing not enough or too much fuel to be sent... Any comments on that???
  1. wont idle down
    By tedrowkj in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2010, 10:04 PM
  2. 3800 s/c wont run HELP!!
    By endars in forum General Tech Discussion
    Last Post: 04-29-2010, 07:30 PM
  3. wont idle
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2009, 07:40 PM
  4. Car wont idle help!!!!!!!!
    By GINOSGTP in forum General Tech Discussion
    Last Post: 05-10-2009, 06:30 AM
  5. 3800 wont idle?
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2008, 03:38 PM
