Yes, only on the GTP...
Okay so I changed my IAC valve, and it seemed to idle and run a lot better! Then I went to the store and when I came out, I had the same problem it would start then die immediately I had to keep the gas down to keep it running. Even then it was sputtering and a lot of smoke was coming outta the exhaust. I managed to start driving and I could put ti to the floor and it would sputter along at no more that 20mph.. I let off some and it sputtered up to about 30, then it seemed to clear up and ran fine again, I had all the power back all of a sudden... Stopped at a light and it was alright, I got on it some and it could break the wheels loose no problem...
I have changed the IAC and the cam shaft positioning sensor so far... This is driving me crazy since it will run fine one monent and not at all/barely the next...
