Thread: L36 to L67 topswap Idler pulley question
Results 1 to 13 of 13
  1. #1 L36 to L67 topswap Idler pulley question
    Jul 2010
    Hackensack, NJ
    For the standoff idler pulley used on the l67 how would that bolt up to the l36? Are the holes pre-drilled on the l36 but not used? Doing a top swap soon so just gathering info. Also if anyone have a 99+ l67 tb, l67 harmonic balancer,l32 MAP, l67 gasket kit that they want to get off their hands at a good price pm me.
  2. #2 Re: L36 to L67 topswap Idler pulley question
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    It mounts on the steel motor bracket(torqu strut) Im guessing you have the aluminum one, so u need to find it at a junkyard.U just mount it on the two long studs that your old coilpack bracket uses and mount the idler on the steel coilpack/motormount bracket.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  3. #3 Re: L36 to L67 topswap Idler pulley question
    Grand Island, Nebraska
    Go to google images and search 3800 sc belt or pulleys. it should give you some helpful images.
  4. #4 Re: L36 to L67 topswap Idler pulley question
    Jersey
    there are holes there on the block, right around where the a/c compressor bolts are, you will be fine
    16' wrx sti- stock
  5. #5 Re: L36 to L67 topswap Idler pulley question
    Jul 2010
    Hackensack, NJ
    Ok thanks everyone for clearing that up. However I have another question.
    How in the world do I attach the SC tentioner to the coil bracket? am i missing a part or something?
  6. #6 Re: L36 to L67 topswap Idler pulley question
    Jersey
    where is your pulley?
    there is supposed to be a pulley that goes on the idler
    16' wrx sti- stock
  7. #7 Re: L36 to L67 topswap Idler pulley question
    Jul 2010
    Hackensack, NJ
    I have the pulley for it. Im just trying to figure out how the tentioner attaches to the bracket
  8. #8 Re: L36 to L67 topswap Idler pulley question
    Jersey
    the black end is going to be facing you. the pulley on the down side, u will see little tits on the top of the back of the idler, one little tit kind of hangs off the edge of the coil pack bracket.
    16' wrx sti- stock
  9. #9 Re: L36 to L67 topswap Idler pulley question
    that seems upside down from the other pictures ive seen. well more like rotated 180 degrees. I thought there was a little groove where the 2 circles went around...heres pics for better explanation. like up the red dots with the 2 circles on the back of the tensioner and the green line with the raised tab thing...
  10. #10 Re: L36 to L67 topswap Idler pulley question
    Jersey
    ^ no sir. My gm service manual and both my cars have it the way as the pic, and all 3800 s/c has it that way. The pulley on the idler should almost line up with the dummy pulley that goes below it on the coil pack bracket.
    and if that isn't convincing enough then think, how does the pulley fit with the coil packs in the way.
    16' wrx sti- stock
  11. #11 Re: L36 to L67 topswap Idler pulley question
    O RLY?
  12. #12 Re: L36 to L67 topswap Idler pulley question
    Jul 2010
    Hackensack, NJ
    Thanks for the reply's. The bracket on the park avenue and Bonnevilles are different as they dont have a dogbone so that may be a cause in the differences. I do understand how to mount it up now. thanks for the help.
  13. #13 Re: L36 to L67 topswap Idler pulley question
    Jersey
    Quote Originally Posted by JoRoW99 View Post
    O RLY?
    LOL!
    maybe for an H body
    16' wrx sti- stock
  1. Idler Pulley Bolt
    By pmanchin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2010, 02:57 PM
  2. idler pulley question
    By 99grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-26-2010, 10:02 AM
  3. Idler pulley really loose
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-24-2010, 03:27 PM
  4. Idler&tensioner pulley help
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 01-15-2010, 10:36 AM
  5. supercharger grooved idler pulley
    By ejechtion54 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-24-2009, 09:20 PM
