Thread: Idler Pulley Bolt
Results 1 to 7 of 7
  1. #1 Idler Pulley Bolt
    SE Level Member pmanchin's Avatar
    Delmar, Maryland
    Hi,
    This is my first post on this forum and I have searched with no avail. I was changing my water pump yesterday and while removing the idler pulley located below the supercharger tensioner, the bolt and washer fell. Since then, I haven't been able to locate it and I can't continue without it. I called the local dealers and they no longer carry the bolt. Is there another fix or does anyone know the size and or where I can get a replacement? I'd greatly appreciate it.
    Thanks in advance,
    Patrick M.
  2. #2 Re: Idler Pulley Bolt
    Charles City, IA
    IIRC the thread on the bolt is m10x1.50 just have to find a washer like the one the was on there or just hit up the junkyard.
    SMGPFC Two Nipple General
  3. #3 Re: Idler Pulley Bolt
    Delmar, Maryland
    Sorry, I'm kind of a newb, thats the length too? What would the length be?
  4. #4 Re: Idler Pulley Bolt
    Donating Users Ibwrong's Avatar
    Oklahoma City
    m10 bolt 1.5 Inches long.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  5. #5 Re: Idler Pulley Bolt
    Squish your arm down directly toward the harmonic balancer and pick the bolt up off the subframe. Yep.. it's honestly right there.
    If need be pull the passenger tire and plastic splash shield to gain a better view of the area.
    I usually drop shiney wrenches or sockets because they are easier to see.
  6. #6 Re: Idler Pulley Bolt
    Delmar, Maryland
    Thanks a lot. Got a replacement.
  7. #7 Re: Idler Pulley Bolt
    GTX Level Member Juanmiguel's Avatar
    Mexico
    I've dropped so many things into the engine bay and never recovered them...
  1. idler pulley question
    By 99grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-26-2010, 10:02 AM
  2. Idler pulley really loose
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-24-2010, 03:27 PM
  3. Idler&tensioner pulley help
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 01-15-2010, 10:36 AM
  4. supercharger grooved idler pulley
    By ejechtion54 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-24-2009, 09:20 PM
