Thread: Terrible MPG.. Any suggestions?
Results 1 to 20 of 26
  1. #1 Re: Terrible MPG.. Any suggestions?
    Apr 2009
    stockton ca
    My guess is tune up time and maybe o2 sensor time
  2. #2 Re: Terrible MPG.. Any suggestions?
    GTX Level Member cerick08GP's Avatar
    If you are really getting 13 mpg that is awful. Be aware that changing your rims ( wheel OD) will change the DIC reading without properly adjusting the PCM.
    That being said, here is a list of tune up items.
    1) Front O2 sensor replacement
    2) Spark plug replacement
    3) MAF cleaning
    4) Proper tire inflation (30psi bare minimum, I personally recommend about 34 psi when checking a warm tire)
    If you address these areas without a change, the problem becomes a lot harder to find. Because then it could be any of a long list of insidious problems.
    Good luck
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  1. Terrible MPG
    By nFavor in forum 5.3L V8 (LS4)
    Last Post: 08-27-2012, 03:00 PM
  2. Terrible knock..need some help!!!!!
    By FooteGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 11:57 AM
  3. Terrible Vibration.
    By 99LuminaLSC in forum Brakes/Suspension/Chassis
    Last Post: 12-31-2008, 10:46 AM
  4. Terrible Gas Mileage
    By TCO in forum General Tech Discussion
    Last Post: 12-16-2008, 01:01 AM
  5. CEL and terrible gas mileage
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 10-06-2008, 04:30 AM
