Thread: Power Steering noise..
Results 1 to 4 of 4
  1. #1 Power Steering noise..
    SE Level Member bryanAZ97GT's Avatar
    Mesa, AZ
    I get the power steering whine ONLY when the a/c compressor is running. any ideas as to why? It whines very loud too.
  2. #2 Re: Power Steering noise..
    Check your belt to see if it is worn...Also, are you sure it isn't the A/C compressor itself?
  3. #3 Re: Power Steering noise..
    Banned
    waterford
    Your belt is worn and its slipping with the extra load of the a/c
  4. #4 Re: Power Steering noise..
    SE Level Member Whiplash Performance's Avatar
    Hillsborough, NJ
    Also check your belt tensonor make sure it has proper tension. I had an issue on one of my cars where when I put the ac on you can see the belt jump up.
    Whiplash Intense Performance Hillsborough, NJ
    Performance Parts & accessories| Powder Coating | Engineering
    Intensewhiplash.com
  1. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  2. Noise coming from steering wheel????
    By jmack98 in forum General Tech Discussion
    Last Post: 04-26-2011, 05:41 PM
  3. Power steering noise
    By Dott in forum General Tech Discussion
    Last Post: 11-30-2009, 01:10 AM
  4. Power steering pump noise
    By minichopper6hp in forum General Tech Discussion
    Last Post: 07-18-2009, 01:57 AM
  5. Turning/Steering Noise
    By chisels1 in forum General Tech Discussion
    Last Post: 06-17-2009, 06:38 AM
