Thread: Power steering noise
Results 1 to 5 of 5
  1. #1 Power steering noise
    ON
    Hi Folks, I'm hearing noise that sounds like it's coming from the power steering rack. I checked the fluid a while back..it was low. It's at the proper level now but when it's wet/cold outside I hear a dull clunk/binding sound when turning.
    Any idea what this may be? I'm guessing it has to do with why the fluid was low to start with...
    Thanks!
  2. #2 Re: Power steering noise
    SE Level Member Piggy's Avatar
    Cincinnati, Ohio
    could possibly be the steering intermediate shaft... is can you feel the clucking in the steering wheel at all?
  3. #3 Re: Power steering noise
    ON
    no clunking in steering wheel.
  4. #4 Re: Power steering noise
    SE Level Member CityStarz's Avatar
    Nov 2009
    pittsburgh PA
    could be inner/outer tierods or internal to the rack.
    if you were low on fluid it is probably leaking somewhere. i know my rack is leaking, most do after a while
    L36|Topswap|3.25|NIC cam|JP Double|Comp 105s|SLP Headers|Full stainless 3" to 2.5" Y|Fully Ported Blower|ST2 TB|FWI|PT|LC-1
  5. #5 Re: Power steering noise
    ON
    I think you're right. Does that involve replacing the inner tie rods? Are they part of the steering rack? I can hear some play/minor clunk when I pull into a drive way with steep incline....the ball joints/outer tie rod ends/hubs are new.
  1. Noise coming from steering wheel????
    By jmack98 in forum General Tech Discussion
    Last Post: 04-26-2011, 05:41 PM
  2. Power steering pump noise
    By minichopper6hp in forum General Tech Discussion
    Last Post: 07-18-2009, 01:57 AM
  3. Turning/Steering Noise
    By chisels1 in forum General Tech Discussion
    Last Post: 06-17-2009, 06:38 AM
  4. ABS, TC, and Power Steering off...:(
    By nikhackgt2 in forum Brakes/Suspension/Chassis
    Last Post: 02-19-2009, 12:09 PM
  5. power steering
    By Toasty in forum General Tech Discussion
    Last Post: 02-23-2008, 01:24 PM
