Thread: Lawngoose's Replacement Engine Advice/Question Thread
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: Lawngoose's Replacement Engine Advice/Question Thread
    Donating Users kfish's Avatar
    Ohio
    Matt outlined something right? Huh...lol
    Anyways...yes...I'd grab the L26...you've just gotta compinsate for the higher compression...meaning headers are a must...and while your blower is off if you haven't done it I'd port it and the TB too. I'd start on a stock sized pulley and go down from there but I don't see any issue with you running a 3.5" with a cam and headers.
    im running a 3.4 on a top swap with an xp and headers, with 19* of timing. i dont know much about the s1x though.
  2. #22 Re: Lawngoose's Replacement Engine Advice/Question Thread
    New crank and cam bolt...your kidding right?
  3. #23 Re: Lawngoose's Replacement Engine Advice/Question Thread
    Jersey
    where did you get your motor from? im in the market, i want an l32
    16' wrx sti- stock
  1. just another headlight question thread
    By CMURDAx in forum Visual/Body Modifications
    Last Post: 08-01-2010, 10:08 AM
  2. gtp engine replacement
    By turbo6 in forum Off Topic Discussion
    Last Post: 06-04-2010, 08:14 AM
  3. Front to rear brake line replacement - need advice
    By bxfl in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2010, 09:56 AM
  4. Need advice on engine build.
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 06:40 PM
  5. Thread tagging question
    By Abrasive in forum Forum Bugs/Suggestions
    Last Post: 02-28-2008, 02:54 PM
