Thread: Rough starting... :-(
Results 1 to 6 of 6
  1. #1 Rough starting... :-(
    SE Level Member Darrylakagodfather's Avatar
    Memphis, TN
    HI, I have a 1997 Pontiac Grand Prix. The car has been quite reliable for the most part, but recently once I crank the key it takes around 3-5 seconds to turn over. I've recently purchased a new battery, starter, and fuel pump. So those are automatically ruled out. I was told the culprit of the problem could possibly be the FPR (Fuel Pressure Regulator). Help please!!!
  2. #2 Re: Rough starting... :-(
    PA
    Quote Originally Posted by Darrylakagodfather View Post
    Pull the rubber vacuum hose off the FPR. If there is gas in the hose, you need to replace the FPR.
    Other than that, you mention that you recently put in a new fuel pump. Was it a stock GM one? Or aftermarket pump? Could be the difference in fuel pumps.
    2001 GSE
  3. #3 Re: Rough starting... :-(
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by Zef_66 View Post
    X2 most hard starts are caused by the FPR bleeding off pressure from the shutdown to the restart
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: Rough starting... :-(
    Memphis, TN
    Ok, I can do that. And it was an OEM Fuel Pump. Firestone replaced it. They get all of their parts from the napa store at the location I go to.
  5. #5 Re: Rough starting... :-(
    HUDSON
    Does it have to crank that long all the time? Does it start faster in the morning
    as apposed to the afternoon? or when the engine is warmed up?
  6. #6 Re: Rough starting... :-(
    Memphis, TN
    Yes. Everytime it sits overnight and I start in the morning its not a problem. And it does seem to take about 3-4 secs to catch when the engine is warm. I took it to the dealership a few days ago and they told me my fuel filter was clogged. I got it replaced and i'm getting a better idle but it's still doing the same thing. Would it be the egr valve or spark plugs?
  1. 01 GTP running rough
    By tazgtp in forum General Tech Discussion
    Last Post: 03-28-2010, 04:10 PM
  2. rough day
    By kjclawson in forum The Rant Forum
    Last Post: 03-13-2010, 06:30 PM
  3. rough idle 02 gtp
    By 02gtpalder in forum General Tech Discussion
    Last Post: 03-06-2010, 01:16 PM
  4. Rough start-up
    By DanGTP in forum PCM Tuning
    Last Post: 02-08-2010, 12:16 AM
  5. '97 GTP, rough idle
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 01:14 AM
