I will roll it up from the passenger side tomorrow and check. I can tell it's gets out of the groove because the windows are tinted, and I can see the cut line on the rear edge of the window (if that makes any sense). Will update tomorrow night.
No sir, both buttons have the same effect. I just meant that I would roll it up from the pass. side so I could listen to the motor. But I don't think it's the motor because I can see where the tint was cut, on the rear of the window, like it starts to lean forward the further it goes up.
its the window guide or the plastic clip that holds the window to the regulator bracket sounds like. Just pull the panel off, it will take like 10 minutes at the most to check. Im assuming you know how to pull the panel off but if you dont check youtube.
