Thread: Windows roll down fine but roll up SLLLOOOOWWLLYYY
Results 1 to 13 of 13
  1. #1 Windows roll down fine but roll up SLLLOOOOWWLLYYY
    SE Level Member azmattaz06's Avatar
    Feb 2009
    Tucson
    I have a good feeling it's not the motors.. i mean would they both be going at the exact same time? Ok so i changed the Alternator yesterday, The battery is still good.. Now what? i was thinking about re-greasing the tracks or something.. Anyone have any idea what it could be? there's no tint so thats not a problem.. The rubber against the window isn't causing it.. PLEASE HELP!! Thanks guys
  2. #2 Re: Windows roll down fine but roll up SLLLOOOOWWLLYYY
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    How slow are we talking? Like longer then the roll down slow, or like 2 minutes slow?
    2006 Grand Prix GXP
  3. #3 Re: Windows roll down fine but roll up SLLLOOOOWWLLYYY
    Feb 2009
    Tucson
    not two minutes slow but i have to sit there and wait for them to roll up and its no fun sitting in 107 degree heat here in Tucson.. they're pretty slow and it really should be much quicker
  4. #4 Re: Windows roll down fine but roll up SLLLOOOOWWLLYYY
    Banned - Busted For Scamming
    Feb 2009
    Mechanical or electrical resistance. Try greasing the tracks first.
  5. #5 Re: Windows roll down fine but roll up SLLLOOOOWWLLYYY
    this is a common problem with these cars. the windows go down fine, they go up slow. mine do it too.
    first things first, open up the switches on your door and clean the contacts on the switch. this should speed them up a little. if not, then it is the motors or regulators.
  6. #6 Re: Windows roll down fine but roll up SLLLOOOOWWLLYYY
    Feb 2009
    Hmmm... mine go up as fast as they go down. Could be the master switch, they go out all the time and mine was replaced when i got the car.
    That would fall under the electrical resistance portion of my previous post.
  7. #7 Re: Windows roll down fine but roll up SLLLOOOOWWLLYYY
    my passenger side works better than the drivers side for the window switch.
  8. #8 Re: Windows roll down fine but roll up SLLLOOOOWWLLYYY
    Wausau, WI
    probably because it goes up/down less often......
  9. #9 Re: Windows roll down fine but roll up SLLLOOOOWWLLYYY
    Jul 2008
    New York
    Also wouldn't an alt rewire speed things up a bit? or is that only if the vehicle is on?
    2006 Grand Prix GXP
  10. #10 Re: Windows roll down fine but roll up SLLLOOOOWWLLYYY
    Wausau, WI
    Quote Originally Posted by azmattaz06 View Post
    my passenger side is ungodly slow and I think it is the motor. I had to replace the driver side one last month. My driver side one is fast now and no issues. The passenger side stops sometimes on the way up just an inch or two from the bottom. If it gets past that point, it goes up but pretty slow.... takes 15 secs or so....grease the tracks and clean the contacts on the switch and if it still doesnt help, then I would guess it is the regs/motors...fwiw
  11. #11 Re: Windows roll down fine but roll up SLLLOOOOWWLLYYY
    SE Level Member Risinnfallen's Avatar
    Lombard, IL
    join the club haha the only thing worse then your window not going up is finding out that u have that problem as your car gets pulled in a car wash
  12. #12 Re: Windows roll down fine but roll up SLLLOOOOWWLLYYY
  13. #13 Re: Windows roll down fine but roll up SLLLOOOOWWLLYYY
    Jun 2013
    Green Bay, WI
    Hello, what is the best way to clean the switch. Electric cleaner spray on the connector? I just replaced the regulator in my daughters car and it rolls up very slowly. I need to try lubing the side tracks and I am wondering if it might be the switch as well. 1998 Grand Prix
  1. Car runs fine but doesn't start the first time i turn the key.. Needs a few turns..
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2009, 02:18 AM
  2. Car takes two or three tries to start.. once warmed up starts fine.. Any info?
    Last Post: 03-08-2009, 03:42 PM
  3. Working fine yesterday, white smoke today
    By Panzer4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2009, 07:30 PM
  4. Window won't roll up
    By Greenlawnracing in forum General Tech Discussion
    Last Post: 02-22-2008, 11:54 PM
