Thread: injectors not pulsing!
Results 1 to 9 of 9
  1. #1 injectors not pulsing!
    Jun 2010
    glidden
    ok its a '97 Gp 3800 non sc. The issue is there is no pulse or juice to the injectors. I can spray carb clean in the throttle body and it runs great while spraying. I have swapped out crank & cam sensors, icm, pcm, map sensor, throttle and mass air sensors, fuel pump. I have even opened up the whole loom and the wires all look good and i have checked them with an multimeter to see if they r broken. i havent checked fuel pressure but i have tried 3 pumps and they all kick in. Is there something i have missed or is there someone out there who has had a simular issue and found a cure? Just up and quit. shows a code p1200 injector control circuit. Thanks for looking.......
    Last edited by HuffCharger; 06-23-2010 at 10:21 PM. Reason: needed to add more fuel pump info
  2. #2 Re: injectors not pulsing!
    Donating Users kfish's Avatar
    Ohio
    how do you know the injectors arent pulsing? have you used noid lights? check the injector fuse.
  3. #3 Re: injectors not pulsing!
    Jun 2010
    glidden
    Fuse is good. but no juice at the injectors. thursday before i left town i tried a different computer and still no change. Ill be digging back into it 2morow. thanks
  4. #4 Re: injectors not pulsing!
    Jan 1970
    Maquoketa, Iowa
    Fuel pump resistor? If you do a search, you may find what your looking for in more detail.
  5. #5 Re: injectors not pulsing!
    Keyser WV
    My dads car is doing the same thing... Still haven't got it working yet, if you figure it out please let me know, Ill let you know if I figure anything out
    My Baby: 1997 Mitsubishi Eclipse GSX. Made in Normal IL USA
  6. #6 Re: injectors not pulsing!
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by kfish View Post
    This.
    I believe the security system will turn off the injectors, as will a bad ICM or crank position sensor. I can't see all of the injector drivers going bad at once, so the PCM wouldn't be my first guess, but it's possible. Any DTCs?
    2001 Buick Regal LS - Almost Stock
  7. #7 Re: injectors not pulsing!
    The injectors are powered by one fuse and toggled by grounds to each individually from the pcm.
    If your security system is pissed off, you will typically start and run for a few moments on the prime shot that was enabled before the security on the key was checked (many models, unsure about yours)
    One other thing to check is the MAF. Unplug it and give her a whirl. The maf can read improperly and cut fuel off.
  8. #8 Re: injectors not pulsing!
    Jun 2010
    glidden
    yes it has a code of p1200 injector control circuit. I am not getting juice to the injectors so I put 12volts to them myself. But it still dont run that way either. so the pcm isnt grounding the injectors either. I was thinking it could possibly be the security system but there isnt a pellet in my key.
  9. #9 Re: injectors not pulsing!
    Jul 2008
    sumter,south carolina
    ive deal with the security issue... it will throw flashing security light and a DTS for security
    02 GTP with mods 05 GP for DD
  1. Pulsing brakes
    By isptech in forum Brakes/Suspension/Chassis
    Last Post: 05-26-2010, 08:17 PM
  2. do i need to get injectors?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2010, 05:48 PM
  3. How are the 42# injectors?
    By $03gp/gt$ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-21-2010, 08:00 PM
  4. Pulsing in 3rd
    By Dohner in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-26-2009, 08:37 AM
